Full Version: Mq5 need help with sources
Using mq5
My folders on nas are:
- movies
- kids
- 3d movies
- 3d kids
Inside xbmc i would like to have all 4 folders in my library (movies)
Then i want a second thing in main menu called "kids" conating kids + kids 3d
Then a third called 3d movies containing "3d movies + 3d kids"
How do i do this?
Also i would like to have the widgets for those things in the main menu..
Thx for your help
Use smart playlists.
One for each menu item.
For the items with two sources add two rules.
For example Kid's would be:
Rule 1: Where 'Path' 'Contains' (your kids folder)
Rule 2: Where 'Path' 'Contains' (your kids 3D folder)
Then make sure you set it to 'Items must match' 'At least one rule'.
And how do i get widgets on the main page then?
Add the playlists to the home screen.
Samurai,
Its empty when i look in it.
Ive set items must match at least one rule.
But library is empty
Very strange
Rules :
path is \kids
Path is \3d kids
Why is it empty?
Path conatins, not path is.
Oh ok, gonna try
It worked, thx mate!
No probs
