HI Anybody know ( i Have red cancel Volume sign UP in the Right Corner ) And I have no Sound , how Do I cancel or turn that OFF ? thank you
You press the mute button. o.o;
Connect a keyboard, hit the '+' button a bunch.
Yep [in]mute or increase volume.
Hi, I'm having the same issue, I have a red no volume sign in the upper right hand corner, I see one of the answers says that means the mute button is active. Where is that and how do I remove the mute? Thanks.
The mute button should be clearly marked on your remote.
Or if you have a keyboard available, press +.
Anyway thread moved to OS independent, as discussions isn't for support requests.
Which skin are you using? Have you pressed the + button your a keyboard?
