Full Version: Gotham Stable release crashing on startup
Pages: 1 2 3
I've been running the Gotham Beta and RC releases succesfully on my Sumvision Cyclone Android x2 and decided to install the Gotham stable release this morning.
After the install, when xbmc is started, it goes through the configuring xbmc for first run sequence then drops out to the android home screen. Further attempts to run xbmc fail completely.
I get the same problem if I do a factory reset and install the stable release. Installing RC1 again brings everything back as normal.
Has anyone else experienced this problem and found a fix?
Many Thanks
Ian
Same behaviour here too, on an RK3066 tablet.
Same here. On an Ouya
Crashlogs people, crashlogs....!
and use pastebin.com for posting them
How can we get debug log without even being able to start the app and turn on debugging?
The xbmc profile folder on android/data does not get created on a clean install (maybe a permissions issue?).
crashlog isn't the same as a Debug Log.
you must use ADB for getting that or there are some android apps that make it easier to get it
Tell me where to find it an i will post it. I cant seem to find it and the Ouya has sketchy Google play support at best.
(2014-05-04, 15:05)Martijn Wrote: [ -> ]crashlog isn't the same as a Debug Log.
Same here. Clean installation and still crashes on startup
Stacktrace from my OUYA.
http://xbmclogs.com/show.php?id=193055
"java.lang.UnsatisfiedLinkError: Cannot load library: link_image[1891]: 109 could not load needed library 'librtmp.so' for 'libxbmc.so' (load_library[1093]: Library 'librtmp.so' not found)"
Testbuild without a possible culprit coming up. ETA ~1 hour ( i hope)
same trouble on my receveir ics based
Cant wait lol
Will do
Does anyone know if Frodo is still available while Gotham's in the shop
Hi Martijn,I've just installed your updated version and xbmc now starts successfully.....
Many Thanks for your assistance
Pages: 1 2 3
