hi, when I setup serverwmc it does not show any of the radios stations in the channel list in the server and when I go to radio channels in xbmc there are no stations. Is there something I need to setup in wmc?
Thanks John
What kind of radio stations are these? Do they come via a TV Tuner or some other device? We currently only support the ones via TV tuners in WMC (audio only channels I guess you could call them), not any other source (such as FM radio)
Yes they are from a tv tuner that has built in FM radio they are found and preset in wmc but in serverwmc it stated radio stations 0
Eventhough the FM tuner is built in to the TV tuner device, the fact they are FM radio stations means we dont currently support them (we only support TV signal audio only stations). There has been a suggestion in the Feature Suggestion thread to add support from them, you might want to add your +1 to that thread if it's something you feel is important!
Sorry
Ok thanks figured since it found the tuner it would add them i'll add my +1 then to thar request
