This is the initial release of the MyPinoyTV addon, which is a subscription on demand site but you can register and get 30 free trial to their entire site. Then use your credential in this addon to view the videos. Most of the videos in the Movies section are giving me "The Direct3d device doesn't support DXVA-HD" error so I'm hoping it just means that my hardware doesn't support it (but I doubt it) so let me know if you the video in the movie section works for anyone. All the TV shows and series seems to work fine for me though. below is the repository where you can install the addon
the site is mypinoy.tv
https://bitbucket.org/dknlght/dk-xbmc-re...paddon.zip
Is it possible to use from norway?
(2014-05-12, 03:11)jolle1 Wrote: [ -> ]Is it possible to use from norway?
I don't think there is any restriction on the site so yes. but if it doesn't work for you let me know
It does not seem to be working! I signed up with mypinoy.tv and then entered the login info in the Addon but nothing happens when I try to search. It does not show any list of movies or TV shows. The only thing I see are "Search" and "Login"!
(2014-12-15, 00:42)xronin Wrote: [ -> ]It does not seem to be working! I signed up with mypinoy.tv and then entered the login info in the Addon but nothing happens when I try to search. It does not show any list of movies or TV shows. The only thing I see are "Search" and "Login"!
I haven't check this addon for awhile so something might have changed. I'll take a look
Hi dknlght,
If this Addon is not working well anymore, what Addon do you recommend for Filipino TV & movies?
just an fyi. This site
http://mypinoy.tv/ seems to no longer need a paid subscription anymore it's free to sign up and you can use the login info on this addon
Sweetness, gonna give it a go later, Thanks dknlght!
