I got XBMC on my NUC setup, things play great after adding a directory to the videos area.
I use sickbeard for TV shows, is there a nice way to view them with an addon, or should I just stick to playing them directly?
Is there a way to remap my rosewell MCE green button to start XBMC?
Is there a way for XBMC to put the computer to sleep after 10 minutes of idle?
Is there a nice way to get netflix working in XBMC? From what I have seen nothing nice exists yet.... like just an addon.
Are there any addons I should get for my movie directories that makes viewing videos better then just directory structure?
Sounds to me like you haven't added your videos to the library I suggest you look at that first.
(2014-05-06, 18:24)Metallifux Wrote: [ -> ]Sounds to me like you haven't added your videos to the library I suggest you look at that first.
I have done that, everything plays a-ok... I was just wondering if there was a pretty view or something? I am more curious about making my sickbeard TV recordings setup nicely.... like a DVR, so you can view the videos and delete when done.
(2014-05-06, 16:44)vivithemage Wrote: [ -> ]Is there a way to remap my rosewell MCE green button to start XBMC?
1. It is possible. Use the mcemapper tool in my signature, change the green button to send a key combination like Win+Alt+X. Set this as shortcut key in the desktop link to xbmc.
2. Use the timer function and set the shutdown action to Suspend (Settings > System > Power Saving).
3. Use a skin like aeon nox and use artwork downloader.
thanks baijuxavior!
I am trying to use aeon nox and MQ5, but when I go to movies or TV I cannot add my source, it makes me browse to it every time. How can I add a new source as a default directory? It also looks like the light weight version of AON does not have very good display options, where MQ5 lets you do the nice display/categories. Is this a gotham/13.0 thing?
That skin is loads better, thanks.
Can I not use the Movies widget to load my movies? Is there an addon/widget that displays downloaded TV shows nicely? I see this skin has a TV shows widget, but it too does not show, or let me add a source directory.
Where/what is this universal scraper?
Videos > Files > Add Videos > Select the folder containing TV Shows and set the content as TV Shows.
aweeeeeeeeeesome, thanks a lot! I am all squared away
