Modifying shortcuts is not too intuitive. I must modify XML files. I think that it would be good idea to let modify shortcut from XBMC setup menu.
(2014-05-06, 17:23)CaBrA Wrote: [ -> ]Modifying shortcuts is not too intuitive. I must modify XML files. I think that it would be good idea to let modify shortcut from XBMC setup menu.
varies depending on the Skin - Check out Aeon MQ5 - high level of customization.
which shortcuts? Favourites?
