Full Version: Fedora RPM Build? Help.
Thanks very much to the amazing folk who made this patch. Would there be a problem in adding the Retroplayer patches to the list of ones applied here?
Fedora seems to patch XBMC, might there be clashes with retroplayer? Any advice?
This is the spec file ...
%global PRERELEASE Gotham_beta3
#%%global DIRVERSION %{version}
# use the line below for pre-releases
%global DIRVERSION %{version}-%{PRERELEASE}
%global _hardened_build 1
Version: 13.0
Release: 0.12.Gotham_beta3%{?dist}
Summary: Media center
License: GPLv2+ and GPLv3+
Group: Applications/Multimedia
URL: http://www.xbmc.org/
Source0: %{name}-%{DIRVERSION}-patched.tar.xz
# xbmc contains code that we cannot ship, as well as redundant private
# copies of upstream libraries that we already distribute.  Therefore
# we use this script to remove the code before shipping it.
# Invoke this script while in the directory where the tarball is located:
# ./xbmc-generate-tarball-xz.sh
Source1: xbmc-generate-tarball-xz.sh
# filed ticket, but patch still needs work
# http://trac.xbmc.org/ticket/9658
Patch1: xbmc-13.0-dvdread.patch
# need to file trac ticket, this patch just forces external hdhomerun
# functionality, needs to be able fallback internal version
Patch2: xbmc-13.0-hdhomerun.patch
# Avoid segfault during goom's configure
# https://bugzilla.redhat.com/1069079
Patch3: xbmc-13.0-libmysqlclient.patch
# External ffmpeg patches
Patch100: 0001-Revert-drop-support-for-external-ffmpeg.patch
Patch101: 0002-Revert-linux-link-ffmpeg-statically.patch
Patch102: 0003-makefile-include.patch
# Optional deps (not in EPEL)
%if 0%{?fedora}
# (libbluray in EPEL 6 is too old.)
%global _with_libbluray 1
%global _with_cwiid 1
%global _with_libssh 1
%global _with_libcec 1
%global _with_external_ffmpeg 1
%endif
%ifarch x86_64 i686
%global _with_crystalhd 1
%global _with_hdhomerun 1
%endif
ExcludeArch: ppc64
BuildRequires: SDL-devel
BuildRequires: SDL_image-devel
BuildRequires: SDL_mixer-devel
BuildRequires: a52dec-devel
BuildRequires: afpfs-ng-devel
BuildRequires: avahi-devel
BuildRequires: bluez-libs-devel
BuildRequires: boost-devel
BuildRequires: bzip2-devel
BuildRequires: cmake
%if 0%{?_with_cwiid}
BuildRequires: cwiid-devel
%endif
BuildRequires: dbus-devel
BuildRequires: desktop-file-utils
BuildRequires: e2fsprogs-devel
BuildRequires: enca-devel
BuildRequires: expat-devel
BuildRequires: faad2-devel
%if 0%{?_with_external_ffmpeg}
BuildRequires: ffmpeg-devel
%endif
BuildRequires: flac-devel
BuildRequires: flex
BuildRequires: fontconfig-devel
BuildRequires: freetype-devel
BuildRequires: fribidi-devel
%if 0%{?el6}
BuildRequires: gettext-devel
%else
BuildRequires: gettext-autopoint
%endif
BuildRequires: glew-devel
BuildRequires: glib2-devel
BuildRequires: gperf
%if 0%{?_with_hdhomerun}
BuildRequires: hdhomerun-devel
%endif
BuildRequires: jasper-devel
BuildRequires: java-devel
BuildRequires: lame-devel
BuildRequires: libXinerama-devel
BuildRequires: libXmu-devel
BuildRequires: libXtst-devel
BuildRequires: libass-devel >= 0.9.7
%if 0%{?_with_libbluray}
BuildRequires: libbluray-devel
%endif
BuildRequires: libcap-devel
BuildRequires: libcdio-devel
%if 0%{?_with_libcec}
BuildRequires: libcec-devel
%endif
%if 0%{?_with_crystalhd}
BuildRequires: libcrystalhd-devel
%endif
BuildRequires: libcurl-devel
BuildRequires: libdca-devel
BuildRequires: libdvdread-devel
%if 0%{?el6}
BuildRequires: libjpeg-devel
%else
BuildRequires: libjpeg-turbo-devel
%endif
BuildRequires: libmad-devel
BuildRequires: libmicrohttpd-devel
BuildRequires: libmms-devel
BuildRequires: libmodplug-devel
BuildRequires: libmpcdec-devel
BuildRequires: libmpeg2-devel
BuildRequires: libogg-devel
# for AirPlay support
BuildRequires: libplist-devel
BuildRequires: libpng-devel
BuildRequires: librtmp-devel
BuildRequires: libsamplerate-devel
BuildRequires: libsmbclient-devel
%if 0%{?_with_libssh}
BuildRequires: libssh-devel
%endif
BuildRequires: libtiff-devel
BuildRequires: libtool
%ifnarch %{arm}
BuildRequires: libva-devel
BuildRequires: libvdpau-devel
%endif
BuildRequires: libvorbis-devel
BuildRequires: libxml-devel
BuildRequires: libxslt-devel
BuildRequires: lzo-devel
BuildRequires: mariadb-devel
# ARM uses GLES
%ifarch %{arm}
BuildRequires: mesa-libEGL-devel
BuildRequires: mesa-libGLES-devel
%endif
BuildRequires: nasm
BuildRequires: pcre-devel
BuildRequires: pulseaudio-libs-devel
BuildRequires: python-devel
BuildRequires: python-pillow
BuildRequires: sqlite-devel
BuildRequires: swig
BuildRequires: systemd-devel
BuildRequires: taglib-devel >= 1.8
BuildRequires: tinyxml-devel
BuildRequires: tre-devel
BuildRequires: trousers-devel
BuildRequires: wavpack-devel
BuildRequires: yajl-devel
BuildRequires: zlib-devel
# nfs-utils-lib-devel package currently broken
#BuildRequires: nfs-utils-lib-devel
# need explicit requires for these packages
# as they are dynamically loaded via XBMC's arcane
# pseudo-DLL loading scheme (sigh)
Requires: libbluray
%endif
Requires: libcec
%endif
%endif
Requires: libmad
Requires: librtmp
# needed when doing a minimal install, see
# https://bugzilla.rpmfusion.org/show_bug.cgi?id=1844
Requires: glx-utils
Requires: xorg-x11-utils
# This is just symlinked to, but needed both at build-time
# and for installation
Requires: python-imaging
%description
XBMC media center is a free cross-platform media-player jukebox and
entertainment hub.  XBMC can play a spectrum of of multimedia formats,
and featuring playlist, audio visualizations, slideshow, and weather
forecast functions, together third-party plugins.
%package devel
Summary: Development files needed to compile C programs against xbmc
Group: Development/Libraries
Requires: %{name} = %{version}-%{release}
%description devel
entertainment hub. If you want to develop programs which use xbmc's
libraries, you need to install this package.
#%%package eventclients
#%Summary: Media center event client remotes
#%%description eventclients
#%This package contains support for using XBMC with the PS3 Remote, the Wii
#%Remote, a J2ME based remote and the command line xbmc-send utility.
#%%package eventclients-devel
#%Summary: Media center event client remotes development files
#%Requires:    %{name}-eventclients = %{version}-%{release}
#%%description eventclients-devel
#%This package contains the development header files for the eventclients
#%library.
%prep
%setup -q -n %{name}-%{DIRVERSION}
%patch1 -p1
%patch2 -p1
%patch3 -p1
%patch100 -p1
%patch101 -p1
%patch102 -p1
%else
  # Remove hdhomerun from the build.
  pushd xbmc/filesystem/
    rm HDHomeRunFile.cpp HDHomeRunFile.h
    rm HDHomeRunDirectory.cpp HDHomeRunDirectory.h
    sed -i Makefile.in -e '/HDHomeRunFile\.cpp/d'
    sed -i Makefile.in -e '/HDHomeRunDirectory\.cpp/d'
    sed -i DirectoryFactory.cpp -e '/HomeRun/d'
    sed -i FileFactory.cpp -e '/HomeRun/d'
  popd
%endif
%build
chmod +x bootstrap
./bootstrap
# Can't use export nor %%configure (implies using export), because
# the Makefile pile up *FLAGS in this case.
./configure \
--prefix=%{_prefix} --bindir=%{_bindir} --includedir=%{_includedir} \
--libdir=%{_libdir} --datadir=%{_datadir} \
--with-lirc-device=/var/run/lirc/lircd \
--enable-external-libraries \
--enable-goom \
--enable-pulse \
--enable-libcec \
%else
--disable-libcec \
%endif
--enable-ssh \
%else
--disable-ssh \
%endif
--disable-dvdcss \
--disable-optimizations --disable-debug \
%ifnarch %{arm}
--enable-gl \
--disable-gles \
--enable-vdpau \
%else
--enable-gles \
--disable-vdpau \
--disable-vaapi \
%ifarch armv7hl \
--enable-tegra \
--disable-neon \
%endif
%ifarch armv7hnl
--enable-neon \
%endif
%endif
CPPFLAGS="-I/usr/include/ffmpeg" \
CFLAGS="$RPM_OPT_FLAGS -fPIC -I/usr/include/afpfs-ng/ -I/usr/include/ffmpeg -I/usr/include/samba-4.0/ -D__STDC_CONSTANT_MACROS" \
CXXFLAGS="$RPM_OPT_FLAGS -fPIC -I/usr/include/afpfs-ng/ -I/usr/include/ffmpeg -I/usr/include/samba-4.0/ -D__STDC_CONSTANT_MACROS" \
%else
CFLAGS="$RPM_OPT_FLAGS -fPIC -I/usr/include/afpfs-ng/ -I/usr/include/samba-4.0/ -D__STDC_CONSTANT_MACROS" \
CXXFLAGS="$RPM_OPT_FLAGS -fPIC -I/usr/include/afpfs-ng/ -I/usr/include/samba-4.0/ -D__STDC_CONSTANT_MACROS" \
%endif
LDFLAGS="-fPIC" \
LIBS=" -lhdhomerun $LIBS" \
%endif
ASFLAGS=-fPIC
make %{?_smp_mflags} VERBOSE=1
%install
rm -rf $RPM_BUILD_ROOT
make DESTDIR=$RPM_BUILD_ROOT install
#make -C tools/EventClients DESTDIR=$RPM_BUILD_ROOT install
# remove the doc files from unversioned /usr/share/doc/xbmc, they should be in versioned docdir
rm -r $RPM_BUILD_ROOT/%{_datadir}/doc/
desktop-file-install \
--dir=${RPM_BUILD_ROOT}%{_datadir}/applications \
$RPM_BUILD_ROOT%{_datadir}/applications/xbmc.desktop
# Normally we are expected to build these manually. But since we are using
# the system Python interpreter, we also want to use the system libraries
install -d $RPM_BUILD_ROOT%{_libdir}/xbmc/addons/script.module.pil/lib
ln -s %{python_sitearch}/PIL $RPM_BUILD_ROOT%{_libdir}/xbmc/addons/script.module.pil/lib/PIL
#install -d $RPM_BUILD_ROOT%{_libdir}/xbmc/addons/script.module.pysqlite/lib
#ln -s %{python_sitearch}/pysqlite2 $RPM_BUILD_ROOT%{_libdir}/xbmc/addons/script.module.pysqlite/lib/pysqlite2
%post
/bin/touch --no-create %{_datadir}/icons/hicolor &>/dev/null || :
%postun
if [ $1 -eq 0 ] ; then
    /usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor &>/dev/null || :
fi
%posttrans
%files
%defattr(-,root,root)
%doc copying.txt CONTRIBUTORS LICENSE.GPL README
%doc docs
%{_bindir}/xbmc
%{_bindir}/xbmc-standalone
%{_libdir}/xbmc
%{_datadir}/xbmc
%{_datadir}/xsessions/XBMC.desktop
%{_datadir}/icons/hicolor/*/*/*.png
%files devel
%{_includedir}/xbmc
#%%files eventclients
#%%defattr(-,root,root)
#%%python_sitelib/xbmc
#%%dir %{_datadir}/pixmaps/xbmc
#%%{_datadir}/pixmaps/xbmc/*.png
#%%{_bindir}/xbmc-j2meremote
#%%{_bindir}/xbmc-ps3d
#%%{_bindir}/xbmc-ps3remote
#%%{_bindir}/xbmc-send
#%%{_bindir}/xbmc-wiiremote
#%%files eventclients-devel
#%%dir %{_includedir}/xbmc
#%%{_includedir}/xbmc/xbmcclient.h
There will most definitely be clashes with the retroplayer based on alpha 12. In the near future (I committed to this week, we'll see if I can hold this promise Wink ) I'll rebase on Gotham Final. There will be much less conflicts, if any, after the rebase.
On linux, I'm having trouble with 32bit vs 64bit emulators. If you're familiar with xbmc's buildsystem, you could help fix this. Otherwise 32-bit fedora will ship with the repo for 64-bit emulators.
Not all all familiar with build systems, sorry duck. I can do C++, but I always saw build systems as something that code in the way of code Big Grin
Once you've finished that rebase, could I in theory get RetroPlayer as a patch to add to the list of patches the Fedora RPM maintainer already applies? I imagine that being easier than putting your branch into the RPM build and applying those other patches to that?
Is this more feasible now?
Yup, you can build from branch retroplayer-13 or retroplayer-13.1. I just compiled an OpenELEC 4.0 build using the 13.1 branch, and most conflicts disappeared.
