I apologize in advance if this is an easy question. Very new to Transparency as a theme and fairly new to XBMC. I haven't been able to figure out how to download subtitles for shows. When I switched from Confluence over to Transparency, I seem to have lost the function to download new subtitles, or do not know how to locate them. I have XBMC subtitle ad on enabled, but while in a show if I choose to browse for subtitles, there is nothing there for the current episode, only old ones. I figure the process is slightly different than in the default skin but I haven't figured it out yet. Any help is very much appreciated.
(2014-05-07, 03:50)suckmykiss Wrote: [ -> ]I apologize in advance if this is an easy question. Very new to Transparency as a theme and fairly new to XBMC. I haven't been able to figure out how to download subtitles for shows. When I switched from Confluence over to Transparency, I seem to have lost the function to download new subtitles, or do not know how to locate them. I have XBMC subtitle ad on enabled, but while in a show if I choose to browse for subtitles, there is nothing there for the current episode, only old ones. I figure the process is slightly different than in the default skin but I haven't figured it out yet. Any help is very much appreciated.
Yes, I Noticed that too...
More detailes to come later... I'm not home right now
the way subtitles are handled is the same across all skins.
which version of xbmc are you using?
(2014-05-07, 08:58)tomer953 Wrote: [ -> ] (2014-05-07, 03:50)suckmykiss Wrote: [ -> ]I apologize in advance if this is an easy question. Very new to Transparency as a theme and fairly new to XBMC. I haven't been able to figure out how to download subtitles for shows. When I switched from Confluence over to Transparency, I seem to have lost the function to download new subtitles, or do not know how to locate them. I have XBMC subtitle ad on enabled, but while in a show if I choose to browse for subtitles, there is nothing there for the current episode, only old ones. I figure the process is slightly different than in the default skin but I haven't figured it out yet. Any help is very much appreciated.
Were you able to find anything that might help me?
