Full Version: Weird Gotham/Aeon menu problem
I am using Gotham (final release version) and AEON MQ.
I have noticed that a number of times I have started up XBMC (Gotham RTM) and the visual menu seems to have got separated logically from what the keyboard is doing.
So you can use the keyboard to move around the menu and you an hear the swipes etc. as if it is moving around, but what's on the screen does not change - it just sits on the Home Menu.
I usually fix it by brining up the favourites and then jumping to settings etc. This seem to re-connect the visual with the logical and all is ok again.
Any thoughts?
Otherwise I am loving Gotham and Aeon.
