(2014-12-20, 05:42)tr0nllam Wrote: [ -> ]I've already tried rebooting and I'm getting nothing.
I have an Asus Chromebox and the only outputs listed are:
HDA Intel, Sam Samsung on HDMI #0
HDA Intel, HDMI #1
HDA Intel, HDMI #2
HDA Intel PCH, ALC283 Analog
Openelec does not seem to be recognizing it.
remove the USB device, reboot, the reconnect it. ssh to the box (via Putty, login/pass is root/openelec), then run the following commands:
dmesg | pastebinit
lsusb -vv | pastebinit
post the resulting URLs
(2014-12-20, 06:22)Matt Devo Wrote: [ -> ] (2014-12-20, 05:42)tr0nllam Wrote: [ -> ]I've already tried rebooting and I'm getting nothing.
HDA Intel, HDMI #1
HDA Intel, HDMI #2
dmesg | pastebinit
http://sprunge.us/CjXa
http://sprunge.us/hBgR
I'm starting to wonder if there is something physically wrong with it. I tried connecting it to 2 different PCs and both got a USB power surge error.
(2014-12-20, 06:31)tr0nllam Wrote: [ -> ]http://sprunge.us/CjXa
it's not being detected at all, and based on your test above, I'd suspect either an error with the hardware itself and/or the USB connector
(2014-12-19, 23:51)Matt Devo Wrote: [ -> ] (2014-12-19, 23:34)Meatwallet Wrote: [ -> ]Sorry, I was trying to install ChromeOS+ Openelec dual boot. I performed the steps exactly as stated in the wiki twice and each time it got me to the same place. I'm not sure if I changed the boot delay or not. Where do I change the boot delay again?
it's one of the options in the dual boot section of the script. Set it back to 30s + chromeOS default, then use [CTRL-L] on the dev boot screen to boot OpenELEC (assuming you have performed the dual boot/OE setup to completion since doing the factory reset).
Thank you! I got it all figured out. As I suspected I it was something stupid, I didn't know the command to enter Kodi. lol. Now my powerline adapter decided to slow down to a crawl. If it's not one thing it's another!
Hello all! This is my first post here. Trying to get into chromebox and xbmc. I have a question though. Will this
asus chromebox run xbmc? Have asus changed something that prevents me from running ubuntu+kodi on this since the guide in the OP was written or is it safe to buy it, diasble write-protect etc and install kodi? Thanks very much for all the help!
PS: DO i need this box in order to play 4k video in xbmc or a cheaper on from the same asus line would do?
(2014-12-20, 11:49)ggp759 Wrote: [ -> ]Hello all! This is my first post here. Trying to get into chromebox and xbmc. I have a question though. Will this asus chromebox run xbmc? Have asus changed something that prevents me from running ubuntu+kodi on this since the guide in the OP was written or is it safe to buy it, diasble write-protect etc and install kodi? Thanks very much for all the help!
this guide was updated less than two weeks ago (as per the subject line), nothing significant has changed since then
the 2955u is the cheapest model in the line, and it will output h.264 4K@24/30Hz no problem.
Thanks so much for the quick reply! Also something else. Is there any specific hardware i need in order for xbmc to passthrough DTS-MA and Dolby Digital TrueHD? Or is it a software limitation? Thanks again.
(2014-12-20, 14:21)ggp759 Wrote: [ -> ]Thanks so much for the quick reply! Also something else. Is there any specific hardware i need in order for xbmc to passthrough DTS-MA and Dolby Digital TrueHD? Or is it a software limitation? Thanks again.
Just have to connected it to a device that can handle those signals and make sure passthrough is on. Just works unlike in the Android world.
Thanks. Works in openelec as well or just ubuntu per the wiki?
Beautifully in OE. I used to use Dual boot but now only single boot OE and I love it. And pick any skin you like they won't slow you down.
(2014-12-20, 16:35)darebee Wrote: [ -> ]Beautifully in OE. I used to use Dual boot but now only single boot OE and I love it. And pick any skin you like they won't slow you down.
Thanks so much for all your answers. Hopefully this is the last one
Does 24p works on openelec? video and audio in sync without setting delays? thanks
Hi.
I am stuck at "Booting from Hard Disk"
I followed the instructions for a standalone setup and everything went fine. Seabios is installed and write protect screw is out of the device.
Now I would like to install Ubuntu from usb. I tried 2 different sticks but if I press Esc nothing happens. After 5 sec I only get the message "Booting from Hard Disk" and thats it.
I read that there is a bug in Seabios that prevents the device from booting from usb? Is this bug already solved?
Hi
I installed openelec on my HP chromebox. But now I want to sell my chromebox. So I want to delete the openelec partition and restore to factory condtitions. Please help me.
(2014-12-20, 16:47)sylvio2000 Wrote: [ -> ]Hi.
The replacement BIOS that gets installed when you install the Standalone install has the USB bug fixed. I've had few problems booting from USB install sticks to install Ubuntu or OpenElec once I've installed it.
(2014-12-20, 16:37)ggp759 Wrote: [ -> ] (2014-12-20, 16:35)darebee Wrote: [ -> ]Beautifully in OE. I used to use Dual boot but now only single boot OE and I love it. And pick any skin you like they won't slow you down.
Thanks so much for all your answers. Hopefully this is the last one Does 24p works on openelec? video and audio in sync without setting delays? thanks
DTS HD/Dolby True HD easier in OE than Ubuntu (where you can end up with PulseAudio issues to sort).
24p works just fine. Not noticed any AV errors - but don't watch huge amounts of 24p content.
I have to same problem... So you say when you have dual boot setup... You get problems if you want to boot from usb?
