I have successfully install in standalone mode openelec kodi version14..
Everything is running amazingly good.
Only one thing I am missing is there is no web browser
is there anyway i can install a web browser ? any body have done it ?
is there a instruction for rookie linux guy?
Has anyone been able to display the fan speed in linux? Lm-sensors (and sensors-detect) does not detect the fan control module.
My fan was making an annoying noise. I managed to get it to stop by turning off the chromebox and tapping it on the bottom a couple of times, but I'm concerned that it isn't running at all now. I can monitor the coretemp via lm-sensors (so I can check if it's actually overheating; I've been unable to get it over 60C so it isn't), but would like to see the fanspeed also.
(2014-12-24, 05:58)malik500 Wrote: [ -> ]I have successfully install in standalone mode openelec kodi version14..
Should've done a chromeos/openelec dual boot. I didn't like chromeos at first but it's a little fantastic OS imho. Something you should consider.
Hi Matt:
Since the Official Kodi was release today,is our Chromebox going to auto update to Kodi?
(2014-12-24, 06:47)movie78 Wrote: [ -> ]Hi Matt:
OpenELEC betas/RCs, if set to auto-update, will update to all subsequent betas/RCs and the eventual stable release, after which it will auto-update to future stable releases only
Kodi official was released, but OpenElec is running a bit behind that and just had RC3 come out (remember, unlike vanilla Kodi, OpenElec has a whole OS behind it to support as well as their own Kodi customizations). I'm sure the official stable version will be out in the next few weeks.
OE RC3 is the final kodi, but missing the "one liner", to change the version :-).
We will change some things though for final (mostly with Cubox powerdown setup), but for the rest, we look very stable for now. Besides some Pentium GT1 issues, those hang the kernel like nothing I have seen before.
(2014-12-24, 07:06)Matt Devo Wrote: [ -> ] (2014-12-24, 06:47)movie78 Wrote: [ -> ]Hi Matt:
kodi update will change the folder structure.
Will this cause an issue with some of us using special skin?
I guess the other issue with 2160/60p content is that that HDMI 1.4 output can't carry 2160/60p 4:2:2/4:4:4 and Intel haven't done the driver trick (yet?) to add 2160/60p 4:2:0 (which is an HDMI 2.0 mode backwards compatible with HDMI 1.4 bandwith) that nVidia did. (Given that pretty much all video content released is 4:2:0 then that isn't a horrific limitation for video quality, though the UI and photos would suffer)
Does the Displayport output on the Chromebox support 2160/60p? (I believe it needs "multi stream" to do this ?)
(2014-12-23, 14:48)nolight Wrote: [ -> ] (2014-12-22, 22:04)Matt Devo Wrote: [ -> ] (2014-12-22, 21:10)nolight Wrote: [ -> ]Hi Matt,
If Openelec was corrupted due to editing of files during SSH and cannot boot up now, but I can still Ctrl-D into Chrome OS, what is the correct way to restore the Openelec installation? Openelec was my default OS.
Should I run the EZ-script (once or twice?) again?
no, we'll edit the file from ChromeOS, just msg me on IRC later on. Unless you don't care about your settings, then you can just re-run the OpenELEC install from the script (once). Then msg me on IRC to figure out your AVR issue.
Ok I haven't changed anything. Will wait for you on IRC today. Or let me know if I should just reinstall OpenElec instead. Thanks.
Hi Matt, how do you edit the config file from ChromeOS? I went into command prompt and only see the script file 3Tfu5W and a couple of other files.
been lurking about for a while and was looking for somthing to replace my main raspberry pi in the living room for somthing with abit more grunt, it looks like a chromebox might just do everything i need which is play video files from my nas at up to 1080p am sorry i dont know if there anything fancy like some of you guys mention this 60p stuff i just know they are 1080p lol.
which chromebox is the perfered model from what i can tell it seems to be the asus celeron with 2gb or ram is there any benifit to getting the 4gb model. if i can get one in the sales for a good price as there quite expensive in the uk otherwise it will mostlikly just be set up to run openelec.
For OpenElec 2GB RAM is fine. I'd go for the Asus if you can - it's supposed to be a bit quieter than the HP and others. It also has a second RAM slot so you can upgrade more easily than with the HP which only has a single SODIMM slot.
(2014-12-24, 00:39)waterskier1018 Wrote: [ -> ] (2014-12-23, 20:23)Matt Devo Wrote: [ -> ] (2014-12-23, 15:42)waterskier1018 Wrote: [ -> ]Yes, I have files in the folder I created as well as the default folders that came on the disk station (music, photos, videos,etc). Can't get to either due to problem. My samsung smart tv can see the default folders but not the one I made.
I assume this shouldn't be a problem? My goal was to put all my stuff in my own folders. It is on the same level as the default folders.
Is there a simple way to wipe out the chrome box so I can start over? Or is that silly if kodi is loading fine?
sounds like a diskstation issue and not an OE/Kodi one, since your TV can't see the folders either. I'd make sure you can access them from a Windows PC before trying again in Kodi.
Does mapping them from the DS as a network drive count, or do I need to setup in another manner to confirm DS is OK? I did this already and it works great.
Bump. Does mapping as a network drive on winPC count at validation for your request above, or do I need to mount the share differently?
