(2015-08-21, 19:10)Matt Devo Wrote: [ -> ]My Gmail address is at the top of the script, and also shown on the screen shot in the first post.
Not sure what you are asking w/r/t Google Apps - they work normally under a dual boot ChromeOS setup. OpenELEC is literally just enough Linux to run Kodi, and doesn't support much besides Kodi add-ons
I am trying to install the chromium browser to be able to search the internet on the stand alone set up but it will not work. It works fine on the duel boot. Is there anything else I could try to use an internet search feature? or a workaround for the chromium browser?
I only asked about the chrome apps because I a was trying to install add blocker and it will not work .
Search openelec forum. There is a chromium browser addon.
(2015-08-21, 21:39)nickr Wrote: [ -> ]Search openelec forum. There is a chromium browser addon.
Thanks for the reply. I have chromium installed just doesn't want to work
(2015-08-22, 02:40)TDB73 Wrote: [ -> ]Thanks for the reply. I have chromium installed just doesn't want to work
what does that mean? I just installed it from the OpenELEC unofficial add-ons repo, and it works fine (on 5.95.3 / VAAPI test builds)
(2015-08-21, 01:23)afmiller Wrote: [ -> ]I think I get it, I'm on the stable build, but there doesn't seem to be a stable build for openelec with kodi 15.0 so I need to get on board with the beta builds. Being on 5.0.8 I'm really far behind considering the current beta 5.95.3. Is that beta build pretty stable? Thanks for straightening things out in my head Matt.
5.0.8 IS the last Stable "Helix", Kodi 14.2. All the later ones are Kodi 15 Isengard, which hasn't been released except in betas and release candidates.
(2015-08-22, 05:04)TonyPh12345 Wrote: [ -> ]5.0.8 IS the last Stable "Helix", Kodi 14.2. All the later ones are Kodi 15 Isengard, which hasn't been released except in betas and release candidates.
this an example of where OpenELEC releases can lag or diverge slightly from Kodi releases. Kodi has had stable releases 15.0 and 15.1, but OpenELEC 6.0 (which is based on Kodi 15.x) is still in beta (5.95.x) - likely due to the expanding number of unique hardware setups OpenELEC supports.
OpenELEC ChromeBox users who want to move to Isengard (15.x) should probably be running the
latest VAAPI EGL test build, since it's based on Kodi 15.1 (vs RC2 for the mainline 5.95.3) and has better PQ and performance to boot. At some point soon it will replace the 5.95.x beta in the script.
The hold up on OE is due to a remote control problem that many users are experiencing, but the development cannot reproduce, and therefore can't fix.
However there is a beta 4 (5.95.4) due this weekend apparently. It will contain kodi 15.1.
I got Kodi installed finally ( I got stuck at the “booting from disk”. For some reason I had to switch back and forth from the Chromebox keyboard to a USB keyboard over and over to get the selection screen). I have one question. When I go to file manager I see two root windows. I’m trying to add source a shared folder. How do you add a shared folder with this setup?
(2015-08-22, 15:42)Scratinthehat Wrote: [ -> ]I got Kodi installed finally ( I got stuck at the “booting from disk”. For some reason I had to switch back and forth from the Chromebox keyboard to a USB keyboard over and over to get the selection screen). I have one question. When I go to file manager I see two root windows. I’m trying to add source a shared folder. How do you add a shared folder with this setup?
this is a general Kodi setup / usage issue, and best handled (and likely already covered) in the
Tips, tricks, and step by step guides forum.
(2015-08-22, 14:10)nickr Wrote: [ -> ]The hold up on OE is due to a remote control problem that many users are experiencing, but the development cannot reproduce, and therefore can't fix.
now i'm using fritsch build with new egl vaapi
http://forum.kodi.tv/showthread.php?tid=231955
hope to see in the future in oe official buuld
ok I choose one second delay for boot now id like to change it to 30 second how am I doing this? I wanna be able to use chrome os
Yeah well nearly the end of the weekend and no news. I really am starting to have doubts about openelec's ongoing viability. And I hate that thought.
(2015-08-22, 05:12)Matt Devo Wrote: [ -> ] (2015-08-22, 05:04)TonyPh12345 Wrote: [ -> ]5.0.8 IS the last Stable "Helix", Kodi 14.2. All the later ones are Kodi 15 Isengard, which hasn't been released except in betas and release candidates.
OpenELEC ChromeBox users who want to move to Isengard (15.x) should probably be running the latest VAAPI EGL test build, since it's based on Kodi 15.1 (vs RC2 for the mainline 5.95.3) and has better PQ and performance to boot. At some point soon it will replace the 5.95.x beta in the script.
Should I only install the files or should I also do the autostart etc, on the vaapi you linked to?
(2015-08-23, 00:25)reglebit Wrote: [ -> ]ok I choose one second delay for boot now id like to change it to 30 second how am I doing this? I wanna be able to use chrome os
boot ChromeOS by pressing CTRL-D on the dev mod boot screen, then run the script and change the delay to 30s.
(2015-08-23, 02:24)nickr Wrote: [ -> ]Yeah well nearly the end of the weekend and no news. I really am starting to have doubts about openelec's ongoing viability. And I hate that thought.
don't think the sky is falling just yet
(2015-08-23, 08:11)Bjur Wrote: [ -> ]Should I only install the files or should I also do the autostart etc, on the vaapi you linked to?
you should fully follow the instructions in the post I linked - autostart, Kodi settings, etc
Hi All,
I've a very quick question.
I have Chrome/XBMC Gotham on a dual boot. I want to upgrade to Kodi. Is there a quick way/wiki page to do this or do I have to uninstall everything and start again?
Thanks,
Duncan
