Full Version: TV Shows video/audio out of sync
Macbook Pro 2009 (Mavericks)
Gotham Final
Adjust Display Refresh Rate To Match Video = OFF
Sync Playback to Display = ON (Audio Clock)
Render Method = Auto Detect
Decoding Method = Hardware Accelerated
Allow Hardware Acceleration (VDADECODER) = ON
Log: http://pastebin.com/sLnZAtJ4
I'd really like to stop switching to VLC when I snuck into bed with my laptop at night.
Which audio settings?
(2014-05-08, 12:43)Memphiz Wrote: [ -> ]Which audio settings?
Hi Memphiz. I'm going to double check when I get home tonight, but AFAIK it should be the default settings.
Could out of sync audio/video anyhow be related to the usage of a USB-headset?
Well first off i would turn off "sync playback to display" and see if this fixes the problem. Then go from there.
I had the problem before turning on "sync playback to display". (Turned it on to see if that would fix it.)
(2014-05-08, 13:01)Memphiz Wrote: [ -> ]Well first off i would turn off "sync playback to display" and see if this fixes the problem. Then go from there.
OK Playing without the USB headset plugged in and using the built-in speakers is flawless.
Audio Settings:
Audio Output Device: default
Number of Channels: 2
Output Configuration: Optimized
Normalize Levels on Downmix: ON
Resample Q: medium
Keep Alive: 1min
Play Gui Sounds: never
