2014-05-08, 10:20
I'm really hoping someone can help me with this as I love my music playlists in XBMC and use them all the time but unfortunately I guess its some adjustments they have made in Gotham which has caused me a fair amount of problems with getting them to work.
I understand that old playlists made in Frodo no longer work so have deleted them but then when setting up the new smart playlists in exactly the same way they will not work.
What I am trying to do is have a "song" smart playlist that brings up random songs and the rule that I use is "album artists". In Frodo this would work fine with no problems but in Gotham it decides that nothing is in the playlist.
I have tried playing around with it to see where the issue lied and have found if I change the playlist to an "artist" one it works but then that is just bringing up the artists and not random tracks the way it used to and how i want it. I can change it back to a "song" playlist and change the rule to "album" and it work but then i have to sift through a very large amount of albums to try and select everything I want which is very impractical.
Can anyone tell me if im missing something or have they currently messed this up?
I really dont want to revert back to Frodo as I love the other adjustments and everything but what with how much i use the playlists im starting to think i may have to if i cant find a solution to this.
Many many thanks in advance!!
