2014-05-08, 20:08
First, very sorry if this has been requested before. I searched and could not find it anywhere in this part of the forum.
First request:
In the settings of XBMC, under the LiveTV > EPG section, there is a setting "Do not show 'no infomation available' labels".
This is great and it works fine for the main TV Channel view (and OSD).
But. Could this same setting also be adapted to the EPG Timeline view? The EpgGrid control?
It is very anoying that channels without EPG do not show up in here, and cannot be selected. Some folks use this as their main view for LiveTV.
Second request:
There is also a setting under LiveTV > Playback called "Start playback minimised". It works fine in the main channel view.
Same here, could this feature\setting also be adapted to the EPG Timeline view so that if a <videowindow> control is present it starts playing there first (minimised). Then a second select would make it go fullscreen (just like main tv channel view).
Thanks in advance.
First request:
Second request:
Thanks in advance.
