hi
Thax for a great skin
i have my movies in the "Right List" display.
the movies that i have watched, have check mark next to them.
but movies that are in progress do not have any indication
i thought it would display that the movie is in progress
any advice, on how to archive this
Thax
Kamlka
It's a watched label. It only indicates those files you've watched.
(2014-05-08, 22:08)Samu-rai Wrote: [ -> ]It's a watched label. It only indicates those files you've watched.
so no label for in progress movies..
i asked because a different skin i used you to have that
is there a way to get in progress label to appear ??
Thax
Kamla
No label for in progress.
XBMC has an in built playlist to show everything in progress, as the skin widgets can also be changed to display this.
i think i was not clear in my question..
if the movies it watched then the watched check mark appear.
but if the movie was watched half way then instead of the watched check mare, the skin should display something else.
currently if the movie was half watched, there is not indication of that. But if i select the movies it give me the option to start where i left off..
is there a way to display this info??
No I understood you
There isn't away to highlight these files as you want within MQ5.
You will have to mod the code.
Thax Samu-rai
any thought where i should start in the code??
