2014-05-08, 22:06
I don't really know if this is possible, but is there a way to set the order of priority that video libraries are scanned for updates in XBMC? I just updated to Gotham. I couldn't find anything in the menus to do it but it would be nice.
It is good to scan all the libraries on startup as things change in different places at different times but it would be better if I could set the order to scan so that something like "Current Series" gets scanned before "Finished Series" and "Latest movies" gets scanned before "Old Movies". If I am waiting for something to import to watch it is more likely in the former than the latter.
But as it stands it does all the movie directories first and this takes a while. I know I can manually scan individual directories so that is a fallback but I figured I might as well ask if there was a way.
It doesn't seem to scan them in the order they are in the sources.xml
Jason
Jason
