Full Version: Gotham refuses to play m4a files
Hi, I don't know why, but now gotham doesn't play any mp4 files... Is there anyone else with the same problem?
Here is some parts of my xbmc.log just in case it is of any help...
Thank you...
00:44:45 T:1920 NOTICE: special://profile/ is mapped to: special://masterprofile/
00:44:45 T:1920 NOTICE: -----------------------------------------------------------------------
00:44:45 T:1920 NOTICE: Starting XBMC (13.0 Git:20140505-f42f5b5). Platform: x86 Win32 32-bit
00:44:45 T:1920 NOTICE: Using Release XBMC x32 build, compiled May 5 2014 by MSVC 160040219 for x86 Win32 32-bit version 0x06000000
00:44:45 T:1920 NOTICE: Running on Windows 7 SP1 64-bit, build 7601
00:44:45 T:1920 NOTICE: Host CPU: Intel® Core™ i7 CPU 860 @ 2.80GHz, 4 cores available
00:44:45 T:1920 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
00:44:45 T:1920 NOTICE: Running with administrator rights
00:44:45 T:1920 NOTICE: Aero is enabled
00:44:45 T:1920 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
00:44:45 T:1920 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
00:44:45 T:1920 NOTICE: special://masterprofile/ is mapped to: C:\Users\Usuario\AppData\Roaming\XBMC\userdata
00:44:45 T:1920 NOTICE: special://home/ is mapped to: C:\Users\Usuario\AppData\Roaming\XBMC\
00:44:45 T:1920 NOTICE: special://temp/ is mapped to: C:\Users\Usuario\AppData\Roaming\XBMC\cache
00:44:45 T:1920 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
00:44:45 T:1920 NOTICE: Local hostname: PC
00:44:45 T:1920 NOTICE: Log File is located: C:\Users\Usuario\AppData\Roaming\XBMC\xbmc.log
00:46:48 T:1920 DEBUG: CDVDDemuxFFmpeg::Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
00:46:48 T:1920 DEBUG: CDVDDemuxFFmpeg::Open - avformat_find_stream_info starting
00:46:48 T:1920 DEBUG: CDVDDemuxFFmpeg::Open - av_find_stream_info finished
00:46:48 T:1920 INFO: ffmpeg[780]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'musicdb://songs/91866.m4a':
00:46:48 T:1920 INFO: ffmpeg[780]: Metadata:
00:46:48 T:1920 INFO: ffmpeg[780]: major_brand : M4A
00:46:48 T:1920 INFO: ffmpeg[780]: minor_version : 0
00:46:48 T:1920 INFO: ffmpeg[780]: compatible_brands: M4A mp42isom
00:46:48 T:1920 INFO: ffmpeg[780]: creation_time : 1994-09-14 16:46:06
00:46:48 T:1920 INFO: ffmpeg[780]: track : 1/13
00:46:48 T:1920 INFO: ffmpeg[780]: genre : Pop
00:46:48 T:1920 INFO: ffmpeg[780]: album : Yours Truly
00:46:48 T:1920 INFO: ffmpeg[780]: artist : Ariana Grande
00:46:48 T:1920 INFO: ffmpeg[780]: title : Honeymoon Avenue
00:46:48 T:1920 INFO: ffmpeg[780]: date : 2013
00:46:48 T:1920 INFO: ffmpeg[780]: gapless_playback: 0
00:46:48 T:1920 INFO: ffmpeg[780]: Duration: 00:05:39.80, start: 0.000000, bitrate: 265 kb/s
00:46:48 T:1920 INFO: ffmpeg[780]: Stream #0:0(eng): Audio: aac (mp4a / 0x6134706D), 44100 Hz, stereo, fltp, 263 kb/s
00:46:48 T:1920 DEBUG: CDVDDemuxFFmpeg::AddStream(0, ...) -> 0
00:46:48 T:1920 DEBUG: FactoryCodec - Audio: passthrough - Opening
00:46:48 T:1920 DEBUG: FactoryCodec - Audio: passthrough - Failed
00:46:48 T:1920 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
00:46:48 T:1920 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
00:46:48 T:1920 DEBUG: CDVDDemuxFFmpeg::SeekTime - unknown position after seek
00:46:48 T:1920 DEBUG: Previous line repeats 1 times.
00:46:48 T:1920 ERROR: ffmpeg[780]: [aac] Number of bands (67) exceeds limit (49).
00:46:48 T:1920 ERROR: ffmpeg[780]: [aac] channel element 0.0 is not allocated
00:46:48 T:1920 ERROR: CAudioDecoder: Error while decoding 1
00:46:48 T:1920 INFO: PAPlayer::QueueNextFileEx - Error reading samples
00:46:48 T:1920 DEBUG: CApplication::OnQueueNextItem : play state was 1, starting 1
00:46:48 T:1920 ERROR: Playlist Player: skipping unplayable item: 0, path [musicdb://songs/91866.m4a]
00:46:48 T:1920 DEBUG: Playlist Player: one or more items failed to play... aborting playback
00:46:48 T:1920 DEBUG: ------ Window Init (DialogOK.xml) ------
00:46:48 T:1920 DEBUG: Keyboard: scancode: 0x50, sym: 0x0112, unicode: 0x0000, modifier: 0x0
00:46:48 T:1920 DEBUG: CApplication::OnKey: down (0xf081) pressed, action is Down
00:46:50 T:1920 DEBUG: Keyboard: scancode: 0x1c, sym: 0x000d, unicode: 0x000d, modifier: 0x0
00:46:50 T:1920 DEBUG: CApplication::OnKey: return (0xf00d) pressed, action is Select
00:46:50 T:1920 DEBUG: ------ Window Deinit (DialogOK.xml) ------
00:46:50 T:1920 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
00:46:50 T:1920 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
00:46:52 T:1920 DEBUG: Keyboard: scancode: 0x01, sym: 0x001b, unicode: 0x001b, modifier: 0x0
00:46:52 T:1920 DEBUG: CApplication::OnKey: escape (0xf01b) pressed, action is PreviousMenu
00:46:52 T:1920 DEBUG: CGUIWindowManager:TonguereviousWindow: Deactivate
00:46:53 T:1920 DEBUG: ------ Window Deinit (MyMusicNav.xml) ------
00:46:53 T:1920 DEBUG: CGUIWindowManager:TonguereviousWindow: Activate new
I have the same problem, i can't play m4a songs since i updated to gotham
I have checked in another computer and it happens too... impossible to play any m4a...
this is already fixed. you can either switch to a nightly build or wait for 13.1
Where do i get the Nightly? Shouldnt this be fixed in a official 13.0 Release?!
(2014-05-10, 23:44)tom1502 Wrote: [ -> ]Where do i get the Nightly? Shouldnt this be fixed in a official 13.0 Release?!
Bugs are still found after an official release because a wider base is using the program. So... nightly, or 13.1.
