Full Version: Vu+ Solo2 + Rpi Zap time very long
Hello,
I just received my new vu+ Solo2, nice box!
I did install the latest Blackhole image on it and up to now everything is working as expected.
I managed to stream live TV on 2 Rpi's running openelec 3.2.4 with the Vu+ PVR Addon.
Aswel SD as HD channels seems to work correctly.
The only "problem" I have for the moment is that I find the zap time very long on the Rpi's.
It takes around five to 10 seconds to change from one channel to an other. Is that normal Huh
Is there anything to improve ?
Are there other PVR addon that I can try with the Vu+ Solo2
Thanks for your help,
SP
Same problem here om my Core i3 with Gotham and Vu Plus addon V1.9.11...
Seems like some sort of bug because Frodo switched a lot faster 2-3 seconds
@splinux
Milhouse builds include a fast channel switch patch which may be worth trying.
It is built from master, so latest builds are newer than Gotham, but could be worth a test.
(2014-05-09, 10:22)splinux Wrote: [ -> ]The only "problem" I have for the moment is that I find the zap time very long on the Rpi's
Why do you need to Zap the channel you are about to stream? Xbmc can stream even without zapping it if tuner can tune to both channels (currently and streaming). I have never used Zap feature on VU+ PVR plug
