2014-05-10, 14:05
2014-05-10, 14:13
Moved to jsonrpc support
2014-05-10, 20:08
ERROR: CDVDPlayer::OpenInputStream - error opening [//192.168.0.110/Video/AMX/300_dolby_cntdwn.m2ts]
2014-05-10, 23:14
Yes, and it is also working if I change to a local file instead.
For example: c:\test.mkv
With Eden this was working on remote system.
Regards
Christian
Regards
Christian
2014-05-11, 10:20
Are you trying to use an UNC path? First of all these should start with \\ and not // but IIRC support for UNC paths was completely removed but I could be wrong.
2014-05-11, 12:22
yes, unc path. Can please anyone of the developers reproduce this, so we know if it is a bug or by design?
We also tried with \ instead of / and received an error pharsing.
Chrisitan
Chrisitan
2014-05-13, 14:58
Backslashes need to be escaped so if you want to send
over JSON-RPC you actually need to send
and the same is required for any other backslashes in the path (not just the leading ones). That's why you receive a parsing error.
\\192.168.0.110
\\\\192.168.0.110
2014-05-13, 15:56
I would say we tried this also... With no success...
Christian
Christian
2014-05-13, 19:21
I'm sorry but "no success" is not a useful error report at all. There can be a thousand reasons why it doesn't work. You need to provide
From your initial log it looks like the JSON-RPC request succeeded but XBMC didn't find a way to actually play the file.
- your exact JSON-RPC request
- the response you get
- a Debug log (wiki) with JSON-RPC debugging enabled
2014-05-14, 06:45
Yes and this seems to be a bug. Because as mentioned if a local path/file is used it works. Same files, just local on c: drive.
2014-05-14, 07:25
See post #9
2014-05-14, 07:44
With local files it is working, this is ok for me. I don't know if I can provide any logs again. I just reported this because it seems to be a bug or is not supported anymore. A dev responsible should be able to test this within minutes. I am not a developer and this xbmc machine is not at my home and the option to test a 3rd party person is required.
This person told me it is little and confusing documented and should be used path or file now with Gotham.
2014-05-16, 20:23
try smb:// instead of \\
