I would like to see "Documentaries" next to "Movies" and "TV Shows" based on the genre "Documentary" or based on the file path "V:\documentaries"(which is easier). This section should include Movies and TV Shows.
Ideally everything included there should not show in "Movies" and "TV Shows".
Is this possible?
I use Gotham and standard skin.
You can create a new smart playlist using path filtering, and then create a new item in the main screen. I don't know if you can do it using standard skin. I'm using Aeon MQ5 and I've create 3 of this kind of items.
(2014-05-12, 12:51)nabz Wrote: [ -> ]You can create a new smart playlist using path filtering, and then create a new item in the main screen. I don't know if you can do it using standard skin. I'm using Aeon MQ5 and I've create 3 of this kind of items.
Thx
Looks like the standard skin cannot handle This. I managed with other skins, but I see some unsupported with Gotham. Can you recommend a skin that is good maintained?
Aeon MQ 5 is supported by Gotham
