Full Version: XMBC wont load. Black Screen
XMBC wont load. This has happened twice already. It works for a couple of hours then it quits.
Here is the Log.
18:53:50 T:1508888816 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:53:50 T:1508888816 NOTICE: -----------------------------------------------------------------------
18:53:50 T:1508888816 NOTICE: Starting XBMC (13.0 Git:20140505-f42f5b5). Platform: ARM Android 32-bit
18:53:50 T:1508888816 NOTICE: Using Debug XBMC x32 build, compiled May 5 2014 by GCC 4.8.0 for ARM Android 32-bit API level 14
18:53:50 T:1508888816 NOTICE: Running on Android 32-bit API level 17 (Android, 3.4.39+ armv7l)
18:53:50 T:1508888816 NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 2 cores available
18:53:50 T:1508888816 NOTICE: Product: sugar_ref001, Device: sugar-ref001, Board: wing - Manufacturer: unknown, Brand: softwinners, Model: SoftwinerEvb, Hardware: sun7i
18:53:50 T:1508888816 NOTICE: ARM Features: Neon enabled
18:53:50 T:1508888816 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
18:53:50 T:1508888816 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
18:53:50 T:1508888816 NOTICE: special://masterprofile/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/userdata
18:53:50 T:1508888816 NOTICE: special://home/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc
18:53:50 T:1508888816 NOTICE: special://temp/ is mapped to: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp
18:53:50 T:1508888816 NOTICE: The executable running is: /system/bin/app_process
18:53:50 T:1508888816 NOTICE: Local hostname: localhost
18:53:50 T:1508888816 NOTICE: Log File is located: /mnt/sdcard/Android/data/org.xbmc.xbmc/files/.xbmc/temp/xbmc.log
18:53:50 T:1508888816 NOTICE: load settings...
18:53:50 T:1508888816 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 17
18:53:50 T:1508888816 ERROR: CSettings: error loading settings definition from special://xbmc/system/settings/settings.xml, Line 0
Failed to open file
18:53:50 T:1508888816 FATAL: Unable to load settings definitions
Same here, exactly the same. anybody have a clue? seems like a problem with settings.xml file..
