Full Version: Customize Context menu
Hello
I have a question that I can't solve or find the right answer....
Can I remove items from the context menu?
When I click on a movie, I would like to apear only "Start from..." and " Start form begining"
Can I do that?
Thank you
many times asked and the answer is still: no
or edit the core code and recompile it
Ok. I'll forget change the menu :-)
Thank you
Press play on a "in progress" movie/episode and you get just that.
I found that I want, using AEON MQ5
Editing DialogContextMenu.xml, solved....I removed the items that I want.
Thank you
