Full Version: can't get remote BUTTON_OK / select working
Hello,
i bought a MCE remote and got almost all buttons working except the "select" one.
I want to use the default OK button on the remot as "select" action in XBMC.
Started with the Wiki (http://wiki.xbmc.org/index.php?title=Keyboard.xml and http://wiki.xbmc.org/index.php?title=Lirc) and followed this guide: http://forum.xbmc.org/showthread.php?tid...ght=KEY_OK.
When pressing the OK button on the remote i get the following from ir-keytable:
[root@manjaro keymaps]# ir-keytable -t
Testing events. Please, press CTRL-C to abort.
1399997762.510846: event type EV_MSC(0x04): scancode = 0x800f0422
1399997762.510846: event type EV_KEY(0x01) key_down: KEY_OK(0x0001)
1399997762.510846: event type EV_SYN(0x00).
1399997762.615966: event type EV_MSC(0x04): scancode = 0x800f0422
1399997762.615966: event type EV_SYN(0x00).
1399997762.863974: event type EV_KEY(0x01) key_up: KEY_OK(0x0001)
1399997762.863974: event type EV_SYN(0x00).
My Lircmap.xml is:
<?xml version="1.0" encoding="UTF-8"?>
<!-- This file contains the mapping of LIRC keys to XBMC keys used in Keymap.xml  -->
<!-- How to add remotes                                                           -->
<!-- <remote device="name_Lirc_calls_the_remote">                                 -->
<!-- For the commands the layout following layout is used                         -->
<!-- <XBMC_COMMAND>LircButtonName</XBMC_COMMAND>                                  -->
<!-- For a list of XBMC_COMMAND's check out the <remote> sections of keymap.xml   -->
<lircmap>
    <remote device="mceusb">
        <!-- new kernel-based lirc button names -->
        <left>KEY_LEFT</left>
        <right>KEY_RIGHT</right>
        <up>KEY_UP</up>
        <down>KEY_DOWN</down>
        <select>KEY_OK</select>
        <start>KEY_HOME</start>
        <back>KEY_BACK</back>
        <record>KEY_RECORD</record>
        <play>KEY_PLAY</play>
        <pause>KEY_PAUSE</pause>
        <stop>KEY_STOP</stop>
        <forward>KEY_FORWARD</forward>
        <reverse>KEY_REWIND</reverse>
        <volumeplus>KEY_VOLUMEUP</volumeplus>
        <volumeminus>KEY_VOLUMEDOWN</volumeminus>
        <pageplus>KEY_CHANNELUP</pageplus>
        <pageminus>KEY_CHANNELDOWN</pageminus>
        <skipplus>KEY_NEXT</skipplus>
        <skipminus>KEY_AGAIN</skipminus>
        <mute>KEY_MUTE</mute>
        <power>KEY_POWER</power>
        <myvideo>KEY_VIDEO</myvideo>
        <mymusic>KEY_AUDIO</mymusic>
        <mytv>LiveTV</mytv>
        <one>KEY_1</one>
        <two>KEY_2</two>
        <three>KEY_3</three>
        <four>KEY_4</four>
        <five>KEY_5</five>
        <six>KEY_6</six>
        <seven>KEY_7</seven>
        <eight>KEY_8</eight>
        <nine>KEY_9</nine>
        <zero>KEY_0</zero>
        <red>KEY_RED</red>
        <green>KEY_GREEN</green>
        <yellow>KEY_YELLOW</yellow>
        <blue>KEY_BLUE</blue>
        <menu>KEY_DVD</menu>
        <clear>KEY_CLEAR</clear>
        <enter>KEY_ENTER</enter>
    </remote>
    <remote device="XboxDVDDongle">
        <play>PLAY</play>
        <pause>PAUSE</pause>
        <stop>STOP</stop>
        <forward>FORWARD</forward>
        <reverse>REVERSE</reverse>
        <left>LEFT</left>
        <right>RIGHT</right>
        <up>UP</up>
        <down>DOWN</down>
        <select>SELECT</select>
        <back>BACK</back>
        <menu>MENU</menu>
        <title>TITLE</title>
        <info>INFO</info>
        <skipplus>SKIP+</skipplus>
        <skipminus>SKIP-</skipminus>
        <display>DISPLAY</display>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
    </remote>
    <remote device="Microsoft_Xbox">
        <play>PLAY</play>
        <stop>STOP</stop>
        <left>LEFT</left>
        <up>UP</up>
        <down>DOWN</down>
        <back>BACK</back>
        <menu>MENU</menu>
        <info>INFO</info>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
    </remote>
    <remote device="PinnacleSysPCTVRemote">
        <play>Play</play>
        <pause>pause</pause>
        <stop>Stop</stop>
        <forward>FForward</forward>
        <reverse>Rewind</reverse>
        <left>Vol-Rew</left>
        <right>Vol+FF</right>
        <up>Chan+Play</up>
        <down>Chan-Stop</down>
        <pageplus>channel+</pageplus>
        <pageminus>channel-</pageminus>
        <select>middle</select>
        <back>undo</back>
        <menu>Menu</menu>
        <title>L</title>
        <info>Info</info>
        <skipplus>next</skipplus>
        <display>Fullscreen</display>
        <record>Record</record>
        <volumeplus>vol+</volumeplus>
        <volumeminus>vol-</volumeminus>
        <mute>Mute</mute>
        <power>Power</power>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
    </remote>
    <remote device="anysee">
        <stop>stop</stop>
        <forward>f1</forward>
        <reverse>f2</reverse>
        <left>left</left>
        <right>right</right>
        <up>chan-up</up>
        <down>chan-down</down>
        <select>ok</select>
        <back>exit</back>
        <menu>menu</menu>
        <title>play</title>
        <info>info</info>
        <skipplus>jump-fwd</skipplus>
        <skipminus>jump-back</skipminus>
        <display>size</display>
        <start>star</start>
        <record>rec</record>
        <volumeplus></volumeplus>
        <volumeminus></volumeminus>
        <mute>mute</mute>
        <power>power</power>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
        <red>red</red>
        <green>green</green>
        <yellow>yellow</yellow>
        <blue>blue</blue>
        <subtitle>subtitle</subtitle>
        <language>audio</language>
    </remote>
    <remote device="iMON-PAD">
        <play>Play</play>
        <pause>Pause</pause>
        <stop>Stop</stop>
        <forward>FastForward</forward>
        <left>Left</left>
        <right>Right</right>
        <up>Up</up>
        <down>Down</down>
        <select>Enter</select>
        <pageplus>Ch+</pageplus>
        <pageminus>Ch-</pageminus>
        <back>Esc</back>
        <back>Backspace</back>
        <menu>Multimon</menu>
        <title>MouseMenu</title>
        <info>SelectSpace</info>
        <skipplus>NextChapter</skipplus>
        <skipminus>PrevChapter</skipminus>
        <display>FullScreen</display>
        <start>MultiMon</start>
        <volumeplus>Vol+</volumeplus>
        <volumeminus>Vol-</volumeminus>
        <mute>Mute</mute>
        <myvideo>MyMovie</myvideo>
        <mymusic>MyMusic</mymusic>
        <mypictures>MyPhoto</mypictures>
        <mytv>MyTV</mytv>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
        <subtitle>Language</subtitle>
    </remote>
    <remote device="Antec_Veris_RM200">
        <forward>KEY_FASTFORWARD</forward>
        <up>KEY_UP</up>
        <select>KEY_ENTER</select>
        <back>KEY_BACKSPACE</back>
        <menu>KEY_MENU</menu>
        <info>Go</info>
        <skipminus>prev</skipminus>
        <start>applauncher</start>
        <mypictures>KEY_PHOTO</mypictures>
        <mytv>KEY_TV</mytv>
        <one>KEY_1</one>
        <two>KEY_2</two>
        <four>KEY_4</four>
        <five>KEY_5</five>
        <six>KEY_6</six>
        <nine>KEY_9</nine>
        <zero>KEY_0</zero>
        <star>Star</star>
        <hash>Hash</hash>
        <playlist>KEY_BOOKMARKS</playlist>
        <teletext>Thumbnail</teletext>
        <title>TaskSwitcher</title>
    </remote>
    <remote    device="MCE_via_iMON">
        <up>KEY_UP</up>
        <menu>PreviousMenu</menu>
        <title>Guide</title>
        <info>KEY_INFO</info>
        <skipplus>KEY_SKIP</skipplus>
        <skipminus>KEY_REPLAY</skipminus>
        <display>Teletext</display>
        <start>WindowsMCE</start>
        <mytv>KEY_TV</mytv>
        <one>KEY_ONE</one>
        <two>KEY_TWO</two>
        <three>KEY_THREE</three>
        <four>KEY_FOUR</four>
        <five>KEY_FIVE</five>
        <six>KEY_SIX</six>
        <seven>KEY_SEVEN</seven>
        <eight>KEY_EIGHT</eight>
        <nine>KEY_NINE</nine>
        <zero>KEY_ZERO</zero>
        <star>Star</star>
        <hash>Hash</hash>
        <clear>KEY_DELETE</clear>
        <red>Red</red>
        <green>Green</green>
        <yellow>Yellow</yellow>
        <blue>Blue</blue>
    </remote>
    <remote device="TwinHanRemote">
        <display>fullscreen</display>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
        <myvideo>favorite</myvideo>
        <volumeminus>rewind</volumeminus>
        <volumeplus>forward</volumeplus>
        <up>ch+</up>
        <left>vol-</left>
        <select>play</select>
        <right>vol+</right>
        <down>ch-</down>
        <menu>recall</menu>
        <stop>stop</stop>
        <mute>mute</mute>
        <info>epg</info>
        <recordedtv>recordlist</recordedtv>
        <title>teletext</title>
    </remote>
    <remote device="linux-input-layer">
    <altname>cx23885_remote</altname>
        <up>KEY_UP</up>
        <start>KEY_SELECT</start>
        <start>KEY_PROG1</start>
        <back>KEY_ESC</back>
        <back>KEY_EXIT</back>
        <back>KEY_CLOSE</back>
        <play>KEY_PLAYPAUSE</play>
        <stop>KEY_STOPCD</stop>
        <channelplus>KEY_CHANNELUP</channelplus>
        <channelminus>KEY_CHANNELDOWN</channelminus>
        <skipplus>KEY_NEXTSONG</skipplus>
        <skipminus>KEY_PREVIOUSSONG</skipminus>
        <skipminus>KEY_PREVIOUS</skipminus>
        <title>KEY_TITLE</title>
        <title>KEY_EPG</title>
        <subtitle>KEY_SUBTITLE</subtitle>
        <language>KEY_LANGUAGE</language>
        <mypictures>KEY_MHP</mypictures>
        <mypictures>KEY_CAMERA</mypictures>
        <mytv>KEY_TV</mytv>
        <liveradio>KEY_RADIO</liveradio>
        <mytv>KEY_TUNER</mytv>
        <one>KEY_1</one>
        <two>KEY_2</two>
        <four>KEY_4</four>
        <five>KEY_5</five>
        <six>KEY_6</six>
        <nine>KEY_9</nine>
        <zero>KEY_0</zero>
        <one>KEY_NUMERIC_1</one>
        <two>KEY_NUMERIC_2</two>
        <three>KEY_NUMERIC_3</three>
        <four>KEY_NUMERIC_4</four>
        <five>KEY_NUMERIC_5</five>
        <six>KEY_NUMERIC_6</six>
        <seven>KEY_NUMERIC_7</seven>
        <eight>KEY_NUMERIC_8</eight>
        <nine>KEY_NUMERIC_9</nine>
        <zero>KEY_NUMERIC_0</zero>
        <star>KEY_NUMERIC_STAR</star>
        <hash>KEY_NUMERIC_POUND</hash>
        <red>KEY_RED</red>
        <info>KEY_PROPS</info>
        <display>KEY_ANGLE</display>
        <display>KEY_ZOOM</display>
        <recordedtv>KEY_PVR</recordedtv>
        <teletext>KEY_TEXT</teletext>
    </remote>
    <remote device="mediacenter">
        <stop>stop</stop>
        <forward>fwd</forward>
        <reverse>rew</reverse>
        <left>left</left>
        <up>up</up>
        <down>down</down>
        <select>ok</select>
        <pageplus>ch+</pageplus>
        <pageminus>ch-</pageminus>
        <back>back</back>
        <menu>clear</menu>
        <title>play</title>
        <info>info</info>
        <display>teletext</display>
        <start>ehome</start>
        <mute>mute</mute>
        <myvideo>video</myvideo>
        <mymusic>music</mymusic>
        <mypictures>pictures</mypictures>
        <mytv>tv</mytv>
        <one>1</one>
        <two>2</two>
        <three>3</three>
        <four>4</four>
        <five>5</five>
        <six>6</six>
        <seven>7</seven>
        <eight>8</eight>
        <nine>9</nine>
        <zero>0</zero>
        <mytv>red</mytv>
        <mymusic>green</mymusic>
        <mypictures>yellow</mypictures>
        <myvideo>blue</myvideo>
    </remote>
    <remote device="devinput">
        <up>KEY_UP</up>
        <start>KEY_MEDIA</start>
        <eject>KEY_EJECT</eject>
        <red>KEY_RED</red>
    </remote>
</lircmap>
and my remote.xml in .xbmc/userdata/keymaps is:
<!-- This file contains the mapping of keys (gamepad, remote, and keyboard) to actions within XBMC -->
<!-- The <global> section is a fall through - they will only be used if the button is not          -->
<!-- used in the current window's section.  Note that there is only handling                       -->
<!-- for a single action per button at this stage.                                                 -->
<!-- For joystick/gamepad configuration under linux/win32, see below as it differs from xbox       -->
<!-- gamepads.        -->
<!-- The format is:                      -->
<!--    <device>                         -->
<!--      <button>action</button>        -->
<!--    </device>                        -->
<!-- To map keys from other remotes using the RCA protocol, you may add <universalremote> blocks -->
<!-- In this case, the tags used are <obc#> where # is the original button code (OBC) of the key -->
<!-- You set it up by adding a <universalremote> block to the window or <global> section:       -->
<!--    <universalremote>             -->
<!--       <obc45>Stop</obc45>         -->
<!--    </universalremote>            -->
<!-- Note that the action can be a built-in function.                 -->
<!--  eg <B>XBMC.ActivateWindow(MyMusic)</B>                         -->
<!-- would automatically go to My Music on the press of the B button. -->
<!-- Joysticks / Gamepads:        -->
<!--   See the sample PS3 controller configuration below for the format.                      -->
<!--  Joystick Name:        -->
<!--   Do 'cat /proc/bus/input/devices' or see your xbmc log file  to find the names of       -->
<!--   detected joysticks. The name used in the configuration should match the detected name. -->
<!--  Button Ids:        -->
<!--   'id' is the button ID used by SDL. Joystick button ids of connected joysticks appear   -->
<!--   in xbmc.log when they are pressed. Use your log to map custom buttons to actions.      -->
<!--  Axis Ids / Analog Controls                                                              -->
<!--   Coming soon.        -->
<keymap>
  <global>
    <keyboard>
      <p>Play</p>
      <q>Queue</q>
      <f>FastForward</f>
      <r>Rewind</r>
      <y>SwitchPlayer</y>
      <left>Left</left>
      <up>Up</up>
      <down>Down</down>
      <left mod="ctrl">analogseekback</left>
      <right mod="ctrl">analogseekforward</right>
      <pageup>PageUp</pageup>
      <pagedown>PageDown</pagedown>
      <return>Select</return>
      <enter>Select</enter>
      <select>Select</select>
      <backspace>Back</backspace>
      <key id='65446'>Back</key>
      <m>ActivateWindow(PlayerControls)</m>
      <s>ActivateWindow(shutdownmenu)</s>
      <escape>PreviousMenu</escape>
      <i>Info</i>
      <menu>ContextMenu</menu>
      <c>ContextMenu</c>
      <space>Pause</space>
      <x>Stop</x>
      <period>SkipNext</period>
      <comma>SkipPrevious</comma>
      <tab>FullScreen</tab>
      <printscreen>Screenshot</printscreen>
      <s mod="ctrl">Screenshot</s>
      <minus>VolumeDown</minus>
      <plus>VolumeUp</plus>
      <equals>VolumeUp</equals>
      <zero>Number0</zero>
      <one>Number1</one>
      <two>Number2</two>
      <three>Number3</three>
      <four>Number4</four>
      <five>Number5</five>
      <six>Number6</six>
      <seven>Number7</seven>
      <eight>Number8</eight>
      <nine>Number9</nine>
      <numpadminus>VolumeDown</numpadminus>
      <numpadplus>VolumeUp</numpadplus>
      <numpadzero>Number0</numpadzero>
      <numpadone>Number1</numpadone>
      <numpadtwo>Number2</numpadtwo>
      <numpadthree>Number3</numpadthree>
      <numpadfour>Number4</numpadfour>
      <numpadfive>Number5</numpadfive>
      <numpadsix>Number6</numpadsix>
      <numpadseven>Number7</numpadseven>
      <numpadeight>Number8</numpadeight>
      <numpadnine>Number9</numpadnine>
      <backslash>ToggleFullScreen</backslash>
      <home>FirstPage</home>
      <end>LastPage</end>
      <power>ActivateWindow(shutdownmenu)</power>
      <sleep>ActivateWindow(shutdownmenu)</sleep>
      <!-- PVR windows -->
      <e>XBMC.ActivateWindowAndFocus(MyPVR, 31,0, 10,0)</e>
      <h>XBMC.ActivateWindowAndFocus(MyPVR, 32,0, 11,0)</h>
      <j>XBMC.ActivateWindowAndFocus(MyPVR, 33,0, 12,0)</j>
      <k>XBMC.ActivateWindowAndFocus(MyPVR, 34,0, 13,0)</k>
      <b>XBMC.ActivateWindowAndFocus(MyPVR, 35,0, 14,0)</b>
      <!-- Multimedia keyboard keys -->
      <browser_back>Back</browser_back>
      <browser_forward/>
      <browser_refresh/>
      <browser_stop/>
      <browser_search/>
      <browser_favorites>ActivateWindow(Favourites)</browser_favorites>
      <browser_home>XBMC.ActivateWindow(Home)</browser_home>
      <volume_mute>Mute</volume_mute>
      <volume_down>VolumeDown</volume_down>
      <volume_up>VolumeUp</volume_up>
      <next_track>SkipNext</next_track>
      <prev_track>SkipPrevious</prev_track>
      <stop>Stop</stop>
      <play_pause>Pause</play_pause>
      <fastforward>FastForward</fastforward>
      <rewind>Rewind</rewind>
      <record/>
      <launch_mail></launch_mail>
      <launch_media_select>XBMC.ActivateWindow(MyMusic)</launch_media_select>
      <launch_app1_pc_icon>ActivateWindow(MyPrograms)</launch_app1_pc_icon>
      <launch_app2_pc_icon>ActivateWindow(MyPrograms)</launch_app2_pc_icon>
      <launch_file_browser/>
      <launch_media_center/>
      <!-- MS Media Center keyboard shortcuts sent by MCE remotes -->
      <!-- See http://msdn.microsoft.com/en-us/library/bb189249.aspx -->
      <p mod="ctrl,shift">Play</p>        <!-- Play -->
      <s mod="ctrl,shift">Stop</s>        <!-- Stop -->
      <p mod="ctrl">Pause</p>             <!-- Pause -->
      <f mod="ctrl,shift">FastForward</f> <!-- Fwd -->
      <b mod="ctrl,shift">Rewind</b>      <!-- Rew -->
      <f mod="ctrl">SkipNext</f>          <!-- Skip -->
      <b mod="ctrl">SkipPrevious</b>      <!-- Replay -->
      <d mod="ctrl">Info</d>              <!-- MCE Details -->
      <f10>VolumeUp</f10>                 <!-- MCE Vol up -->
      <f9>VolumeDown</f9>                 <!-- MCE Vol down -->
      <f8>Mute</f8>                       <!-- MCE mute -->
      <g mod="ctrl">ActivateWindowAndFocus(MyPVR, 31,0, 10,0)</g>  <!-- MCE Guide -->
      <m mod="ctrl">ActivateWindow(music)</m>    <!-- MCE My music -->
      <i mod="ctrl">ActivateWindow(pictures)</i> <!-- MCE My pictures -->
      <e mod="ctrl">ActivateWindow(video)</e>    <!-- MCE videos -->
      <m mod="ctrl,shift">PlayerControl(ShowVideoMenu)</m>         <!-- MCE DVD menu -->
      <o mod="ctrl">ActivateWindowAndFocus(MyPVR, 34,0, 13,0)</o>  <!-- MCE Recorded TV -->
      <t mod="ctrl">ActivateWindowAndFocus(MyPVR, 32,0, 11,0)</t>  <!-- MCE Live TV  -->
      <t mod="ctrl,shift">ActivateWindow(MyPVR)</t>                <!-- MCE My TV -->
      <a mod="ctrl">ActivateWindowAndFocus(MyPVR, 33,0, 12,0)</a>  <!-- MCE My Radio -->
      <!-- MCE keypresses without an obvious use in XBMC -->
      <u mod="ctrl">Notification(MCEKeypress, DVD subtitle, 3)</u>
      <a mod="ctrl,shift">Notification(MCEKeypress, DVD audio, 3)</a>
    </keyboard>
  </global>
  <LoginScreen>
    <keyboard>
      <end mod="ctrl">XBMC.ShutDown()</end>
    </keyboard>
  </LoginScreen>
  <Home>
    <keyboard>
      <i>info</i>
    </keyboard>
  </Home>
  <VirtualKeyboard>
    <keyboard>
      <backspace>Backspace</backspace>
    </keyboard>
  </VirtualKeyboard>
  <MyTV>
    <keyboard>
      <delete>Delete</delete>
      <m>Move</m>
      <r>Rename</r>
    </keyboard>
  </MyTV>
  <MyFiles>
    <keyboard>
      <space>Highlight</space>
      <m>Move</m>
      <r>Rename</r>
    </keyboard>
  </MyFiles>
  <MyMusicPlaylist>
    <keyboard>
      <space>Back</space>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyMusicPlaylist>
  <MyMusicPlaylistEditor>
    <keyboard>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyMusicPlaylistEditor>
  <MyMusicFiles>
    <keyboard>
      <space>Playlist</space>
      <q>Queue</q>
    </keyboard>
  </MyMusicFiles>
  <MyMusicLibrary>
    <keyboard>
      <q>Queue</q>
    </keyboard>
  </MyMusicLibrary>
  <FullscreenVideo>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <period>StepForward</period>
      <comma>StepBack</comma>
      <backspace>Fullscreen</backspace>
      <quote>SmallStepBack</quote>
      <opensquarebracket>BigStepForward</opensquarebracket>
      <closesquarebracket>BigStepBack</closesquarebracket>
      <return>OSD</return>
      <enter>OSD</enter>
      <m>OSD</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <z>AspectRatio</z>
      <t>ShowSubtitles</t>
      <t mod="ctrl">SubtitleAlign</t>
      <l>NextSubtitle</l>
      <left>StepBack</left>
      <right>StepForward</right>
      <up>ChapterOrBigStepForward</up>
      <down>ChapterOrBigStepBack</down>
      <a>AudioDelay</a>
      <escape>Fullscreen</escape>
      <c>Playlist</c>
      <v>XBMC.ActivateWindow(Teletext)</v>
      <up mod="ctrl">SubtitleShiftUp</up>
      <down mod="ctrl">SubtitleShiftDown</down>
      <pageup>SkipNext</pageup>
      <pagedown>SkipPrevious</pagedown>
    </keyboard>
  </FullscreenVideo>
  <VideoTimeSeek>
    <keyboard>
    </keyboard>
  </VideoTimeSeek>
  <FullscreenInfo>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <o>CodecInfo</o>
      <i>Back</i>
      <d mod="ctrl">Back</d>
      <m>OSD</m>
    </keyboard>
  </FullscreenInfo>
  <PlayerControls>
    <keyboard>
      <m>Back</m>
    </keyboard>
  </PlayerControls>
  <Visualisation>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <enter>OSD</enter>
      <m>OSD</m>
      <i>Info</i>
      <p>ActivateWindow(VisualisationPresetList)</p>
      <v>ActivateWindow(VisualisationSettings)</v>
      <n>ActivateWindow(MusicPlaylist)</n>
      <left>SkipPrevious</left>
      <right>SkipNext</right>
      <up>IncreaseRating</up>
      <down>DecreaseRating</down>      <!--<back>NextPreset</back>!-->
      <o>CodecInfo</o>
      <l>LockPreset</l>
      <escape>FullScreen</escape>
      <g>XBMC.ActivateWindow(PVROSDGuide)</g>
      <c>XBMC.ActivateWindow(PVROSDChannels)</c>
    </keyboard>
  </Visualisation>
  <MusicOSD>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </MusicOSD>
  <VisualisationSettings>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <v>Back</v>
    </keyboard>
  </VisualisationSettings>
  <VisualisationPresetList>
    <keyboard>
      <f>FastForward</f>
      <r>Rewind</r>
      <m>Back</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <p>Back</p>
      <v>Back</v>
    </keyboard>
  </VisualisationPresetList>
  <SlideShow>
    <keyboard>
      <zero>ZoomNormal</zero>
      <one>ZoomLevel1</one>
      <two>ZoomLevel2</two>
      <three>ZoomLevel3</three>
      <four>ZoomLevel4</four>
      <five>ZoomLevel5</five>
      <six>ZoomLevel6</six>
      <seven>ZoomLevel7</seven>
      <eight>ZoomLevel8</eight>
      <nine>ZoomLevel9</nine>
      <i>Info</i>
      <o>CodecInfo</o>
      <period>NextPicture</period>
      <comma>PreviousPicture</comma>
      <plus>ZoomIn</plus>
      <minus>ZoomOut</minus>
      <return>Rotate</return>
      <enter>Rotate</enter>
      <r>Rotate</r>
    </keyboard>
  </SlideShow>
  <ScreenCalibration>
    <keyboard>
      <return>NextCalibration</return>
      <enter>NextCalibration</enter>
      <d>ResetCalibration</d>
      <r>NextResolution</r>
    </keyboard>
  </ScreenCalibration>
  <GUICalibration>
    <keyboard>
    </keyboard>
  </GUICalibration>
  <VideoOSD>
    <keyboard>
      <m>Back</m>
      <g mod="ctrl">Back</g> <!-- MCE Guide button -->
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </VideoOSD>
  <VideoMenu>
    <keyboard>
      <m>OSD</m>
      <i>Info</i>
      <o>CodecInfo</o>
      <z>AspectRatio</z>
      <l>NextSubtitle</l>
      <a>AudioDelay</a>
      <enter>Select</enter>      <!-- backspace>Fullscreen</backspace -->
    </keyboard>
  </VideoMenu>
  <OSDVideoSettings>
    <keyboard>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </OSDVideoSettings>
  <OSDAudioSettings>
    <keyboard>
      <i>Info</i>
      <o>CodecInfo</o>
    </keyboard>
  </OSDAudioSettings>
  <VideoBookmarks>
    <keyboard>
    </keyboard>
  </VideoBookmarks>
  <MyVideoLibrary>
    <keyboard>
      <w>ToggleWatched</w>
    </keyboard>
  </MyVideoLibrary>
  <MyVideoFiles>
    <keyboard>
      <q>Queue</q>
    </keyboard>
  </MyVideoFiles>
  <MyVideoPlaylist>
    <keyboard>
      <space>Back</space>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </MyVideoPlaylist>
  <MyPictures>
    <keyboard>
    </keyboard>
  </MyPictures>
  <ContextMenu>
    <keyboard>
      <c>Back</c>
      <menu>Back</menu>
    </keyboard>
  </ContextMenu>
  <Scripts>
    <keyboard>
      <i>info</i>
    </keyboard>
  </Scripts>
  <MusicInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </MusicInformation>
  <MovieInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </MovieInformation>
  <PictureInfo>
    <keyboard>
      <i>Back</i>
      <o>Back</o>
    </keyboard>
  </PictureInfo>
  <Teletext>
    <keyboard>
      <v>Back</v>
    </keyboard>
  </Teletext>
  <Favourites>
    <keyboard>
      <backspace>Close</backspace>
      <u>MoveItemUp</u>
      <d>MoveItemDown</d>
    </keyboard>
  </Favourites>
  <NumericInput>
    <keyboard>
    </keyboard>
  </NumericInput>
  <FullscreenLiveTV>
    <keyboard>
      <left>PreviousChannelGroup</left>
      <right>NextChannelGroup</right>
      <up>ChannelUp</up>
      <down>ChannelDown</down>
    </keyboard>
  </FullscreenLiveTV>
  <PVROSDChannels>
    <keyboard>
      <escape>Close</escape>
      <c>Close</c>
    </keyboard>
  </PVROSDChannels>
  <PVROSDGuide>
    <keyboard>
    </keyboard>
  </PVROSDGuide>
  <PVROSDDirector>
    <keyboard>
    </keyboard>
  </PVROSDDirector>
  <PVROSDCutter>
    <keyboard>
    </keyboard>
  </PVROSDCutter>
  <MyTVSettings>
    <keyboard>
      <backspace>PreviousMenu</backspace>
    </keyboard>
  </MyTVSettings>
  <FileBrowser>
    <keyboard>
    </keyboard>
  </FileBrowser>
  <ShutdownMenu>
    <keyboard>
      <s>Back</s>
    </keyboard>
  </ShutdownMenu>
  <AddonInformation>
    <keyboard>
      <i>Back</i>
    </keyboard>
  </AddonInformation>
  <AddonSettings>
    <keyboard>
    </keyboard>
  </AddonSettings>
</keymap>
This looks for me like the key event "KEY_OK" should be translated by the Lircmap into "select" which should end up with the keymap into " <select>Select</select>" but it isn't working.
Nothing happens when i press the OK button while in the main menue of XBMC. Although left, up, right, down, mute and others are working fine.
Anyone any idea?
Thank you in advance!
