Full Version: TVHeadend command client: Unable to stat path
Im getting the following error on startup it has started happening after I changed the recording system path from the default value "Storage/Recordings" I have since changed it back but still getting the same error and unable to record.
Log File
The path is probably nonexisting or not read/writable. Remember that case sensitivity matters.
