Full Version: 13.1 Beta1 - Bug when updating from MyMusic20.db to MyMusic46.db?
After Beta1 came along, I did an upgrade of my (very old) xbmc installation.
The first run, the debug log says:
20:33:52 T:3520  NOTICE: Old database found - updating from version 20 to 46
20:33:52 T:3520   DEBUG: Copying from MyMusic20.db to MyMusic46 at C:\util\Xbmc\portable_data\userdata\Database\
20:34:25 T:3520  NOTICE: Attempting to update the database MyMusic46 from version 20 to 46
20:34:25 T:3520   DEBUG: Cleaning indexes from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:34:25 T:3520   DEBUG: Cleaning views from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:34:25 T:3520   DEBUG: Cleaning triggers from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:34:27 T:3520    INFO: CMusicDatabase::CreateAnalytics - creating indices
20:34:27 T:3520   ERROR: SQL: Abort due to constraint violation
                                            Query: CREATE UNIQUE INDEX idxAlbumGenre_1 ON album_genre ( idAlbum, idGenre )
20:34:27 T:3520   ERROR: Exception updating database MyMusic46 from version 20 to 46
20:34:27 T:3520   ERROR: Error updating database MyMusic46 from version 20 to 46
20:34:27 T:3520  NOTICE: Old database found - updating from version 18 to 46
20:34:27 T:3520   DEBUG: Copying from MyMusic18.db to MyMusic46 at C:\util\Xbmc\portable_data\userdata\Database\
20:34:27 T:3520  NOTICE: Attempting to update the database MyMusic46 from version 18 to 46
20:34:27 T:3520   DEBUG: Cleaning indexes from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:34:27 T:3520   DEBUG: Cleaning views from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:34:27 T:3520   DEBUG: Cleaning triggers from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
then I restarted:
20:36:32 T:3204  NOTICE: Attempting to update the database MyMusic46 from version 18 to 46
20:36:32 T:3204   DEBUG: Cleaning indexes from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:36:36 T:3204   DEBUG: Cleaning views from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
20:36:37 T:3204   DEBUG: Cleaning triggers from database MyMusic46.db at C:\util\Xbmc\portable_data\userdata\Database\
(uses 1 minute on this EVERY start)
I ended up moving all MyMusic*.db files to a subdir and then restarted the PC. finally it worked fine.
I'm not sure this is a bug or not, but it seems like it to me?
It might be, it might not. The index violation suggests you have multiple albums linking to the same genres multiple times. This shouldn't be happening.
I dunno which version ran music database version 20. IIRC Eden was v18, so that's somewhere between Eden + Frodo (i.e. some build that could have had broken stuff in it).
okay. i don't think i'll investigate more. thanks for your responding jmarshall. i leave this thread in case somebody else end up here while googling.
