Full Version: service.subtitles.unacs
Pages: 1 2 3 4 5 6 7 8
Thanks the team for the perfect development of Fusion tv.
I have access to more than 5 accounts and in all absent Animal Planet. I want to ask whether this is happening only to me and do you have access to watch this channel ?
Bsc service + iptv simple client preview
watch gallery
I can't find bsc fusion tv on bg.addons anymore. How to fix?
I can install Fusion tv from bg add-ons from section program but version is 0.0.1 and does not working.
(2015-09-27, 02:02)topki_111 Wrote: [ -> ]Bsc service + iptv simple client preview
It's getting better and better Big Grin
watch gallery
Hi topki_111,
How to configure PVR iptv simple client to work with BSC ?
(2015-09-27, 11:48)hideman697 Wrote: [ -> ]Hi topki_111,
You need to point iptv simple client to files below.
Once bsc service is configured it generate bulsat.m3u and bulsat.xml.gz files.
On windows files for iptv simple client are located here:
C:\Users\<USER>\AppData\Roaming\Kodi\userdata\addon_data\service.bscfusion\dat
Please find usredata paths for other platforms here.
Thanks, works perfectly!!!
(2015-09-27, 12:08)topki_111 Wrote: [ -> ]
I have not folder service.bscfusion only plugin.video.bscfusion.
(2015-09-27, 15:36)hideman697 Wrote: [ -> ]
You should install bscfusion program, it will create folder and files.
Hello,
Thank you for developing the Fusion addon. You've done a really amazing work!
Regards
Hello,
Thank you for the nice plugin.
On PC it works great.
On android 4.2 with kodi 14.2 there is a problem creating xxxxxx.xml.gz.
Tried with 2 different android devices.
Login with account is o.k.
m3u file is o.k.
Retrieving EPG data seems o.k.
After that there are multiple errors in python scrips concerning python functions, parameters. Seems like difference in the syntax between PC/Windows and Android.
Would you check if you find a little time?
Thanx in advance.
(2015-09-28, 15:14)Jappy Wrote: [ -> ]Hello,
m3u file is o.k.
Thanx in advance.
Without log file, nothing can be done.
I made new installations of Android TV box, everything is under control but channels logo and EPG are missing.
Any idea what I failed to do?
At risk of becoming tedious want to ask the creators of Fusion TV to return to the old version in BG repo - my elderly parents are difficult to fix with the new changes ( 85 years, this is understandable )
(2015-09-28, 19:27)moskivb Wrote: [ -> ]I made new installations of Android TV box, everything is under control but channels logo and EPG are missing.
log file
(2015-09-28, 19:27)moskivb Wrote: [ -> ]At risk of becoming tedious want to ask the creators of Fusion TV to return to the old version in BG repo - my elderly parents are difficult to fix with the new changes ( 85 years, this is understandable )
Probably you can find cached version 0.0.9 other repos, but it will be not supported, anymore.
Hi Topki_111,
I just noticed a difference in the quality of the picture provided by service.bscfusion and plugin.video.bscfusion.
It looks like plugin.video.bscfusion provides a better quality.
Is this possible or is it just my imagination? I guess they use the same streaming source after all...
Regards
