Full Version: service.subtitles.unacs
Pages: 1 2 3 4 5 6 7 8
(2015-09-28, 21:05)harrygg Wrote: [ -> ]Hi Topki_111,
I just noticed a difference in the quality of the picture provided by service.bscfusion and plugin.video.bscfusion.
It looks like plugin.video.bscfusion provides a better quality.
Is this possible or is it just my imagination? I guess they use the same streaming source after all...
Regards
You can check channel codec info.
(2015-04-27, 14:28)topki_111 Wrote: [ -> ]
(2015-04-26, 08:41)publicimage Wrote: [ -> ]At first worked well but after a while started to shows errors
"Error Cleanup"
"Failed to download ..."
Android 4.4.2
Kodi 14
Using the latest release from the Bulgarian repo
That issue was fixed in previous version.
Can you please, double check add-on version?
Latest version is 0.0.10, also you can try to manually force update it - just use "service.subtitles.unacs" insteadof "plugin.video.bscfusion".
Anyway it seems that script can't cleanup it working folder.
Issue was caused when in folder, there are file names with 'cp-1251' characters.
You can try to remove that folder manually:
Android/data/org.xbmc.kodi/files/.kodi/addon_data/service.subtitles.unacs
Hello, thank you for your time.
I am writing about Fusion plugin not about service-subtitles.unacs. I do not have such folder to delete it manualy.
Here it is the part of the log:
Quote:22:55:00 T:1782890248 DEBUG: bool CApplication:TonguerocessMouse(): trying mouse action leftclick
22:55:00 T:1782890248 DEBUG: ------ Window Init (DialogAddonSettings.xml) ------
22:55:00 T:1782890248 DEBUG: LocalizeStrings: no translation available in currently set gui language, at path /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/resources/language/English (US)
22:55:00 T:1782890248 DEBUG: LocalizeStrings: no strings.po file exist at /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/resources/language/English, fallback to strings.xml
22:55:03 T:1782890248 DEBUG: bool CApplication:TonguerocessMouse(): trying mouse action leftclick
22:55:03 T:1782890248 DEBUG: Unfocus WindowID: 10140, ControlID: 102
22:55:05 T:1782890248 DEBUG: bool CApplication:TonguerocessMouse(): trying mouse action leftclick
22:55:05 T:1782890248 DEBUG: Unfocus WindowID: 10140, ControlID: 200
22:55:05 T:1866895392 NOTICE: Thread LanguageInvoker start, auto delete: false
22:55:05 T:1866895392 INFO: initializing python engine.
22:55:05 T:1866895392 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): start processing
22:55:05 T:1940349104 DEBUG: Thread JobWorker 1940349104 terminating (autodelete)
22:55:05 T:1866895392 NOTICE: -->Python Interpreter Initialized<--
22:55:05 T:1866895392 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): the source file to load is "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py"
22:55:05 T:1866895392 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): setting the Python path to /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.garepobg/lib:/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib:/:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python26.zip:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python2.6:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python2.6/plat-linux3:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python2.6/lib-tk:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python2.6/lib-old:/data/app/org.xbmc.kodi-1.apk/assets/python2.6/lib/python2.6/lib-dynload
22:55:05 T:1866895392 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): entering source directory /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion
22:55:05 T:1866895392 DEBUG: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): instantiating addon using automatically obtained id of "service.bscfusion" dependent on version 2.1.0 of the xbmc.python api
22:55:05 T:1806058720 DEBUG: Thread JobWorker 1806058720 terminating (autodelete)
22:55:05 T:1782890248 DEBUG: SECTION:UnloadDelayed(DLL: libImageLib-arm.so)
22:55:05 T:1782890248 DEBUG: Unloading: /libImageLib-arm.so
22:55:06 T:1782890248 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
22:55:06 T:1866895392 ERROR: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/script.module.requests/lib/requests/packages/urllib3/util/ssl_.py:90: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. For more information, see https://urllib3.readthedocs.org/en/lates...ormwarning.
22:55:57 T:1866895392 ERROR: Previous line repeats 13 times.
22:55:57 T:1866895392 ERROR: Traceback (most recent call last):
22:55:57 T:1866895392 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py", line 118, in <module>
22:55:57 T:1782890248 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
22:55:57 T:1866895392 ERROR: if b.gen_all(force):
22:55:57 T:1866895392 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/resources/lib/bsc.py", line 250, in gen_all
22:55:57 T:1801614056 INFO: CActiveAESink::OpenSink - initialize sink
22:55:57 T:1801614056 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
22:55:57 T:1866895392 ERROR: w.write(out, pretty_print=True)
22:55:57 T:1866895392 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/resources/lib/xmltv.py", line 610, in write
22:55:57 T:1866895392 ERROR: et.write(file, self.encoding, xml_declaration=True)
22:55:57 T:1866895392 ERROR: TypeError: write() got an unexpected keyword argument 'xml_declaration'
22:55:57 T:1782890248 DEBUG: SECTION:LoadDLL(libImageLib-arm.so)
22:55:57 T:1801614056 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
22:55:57 T:1801614056 DEBUG: Output Device : android
22:55:57 T:1801614056 DEBUG: Sample Rate : 48000
22:55:57 T:1801614056 DEBUG: Sample Format : AE_FMT_S16NE
22:55:57 T:1801614056 DEBUG: Channel Count : 2
22:55:57 T:1801614056 DEBUG: Channel Layout: FL,FR
22:55:57 T:1782890248 DEBUG: Loading: /data/app-lib/org.xbmc.kodi-1/libImageLib-arm.so
22:55:57 T:1801614056 DEBUG: Frames : 1536
22:55:57 T:1801614056 DEBUG: Frame Samples : 3072
22:55:57 T:1801614056 DEBUG: Frame Size : 4
22:55:57 T:1782890248 DEBUG: ------ Window Deinit (DialogExtendedProgressBar.xml) ------
22:55:58 T:1866895392 INFO: CPythonInvoker(10, /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion/exec.py): script successfully run
22:55:58 T:1866895392 INFO: Python script stopped
And finaly there is message "Module Import failed"
Hello,
After removing the mentioned folder xxxxxx.xml.gz appears but xxxxx.xml file is empty.
I set the OS type to "Android" in the settings interface.
Quote:Traceback (most recent call last):
07:40:05 T:1849361560 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion-master/exec.py", line 120, in <module>
07:40:05 T:1849361560 ERROR: if b.gen_all(force):
07:40:05 T:1849361560 ERROR: File "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion-master/resources/lib/bsc.py", line 258, in gen_all
07:40:05 T:1849361560 ERROR: with gzip.open(os.path.join(self.__path, '', 'bulsat.xml.gz'), 'w+', 9) as f_lmx:
07:40:05 T:1849361560 ERROR: AttributeError: GzipFile instance has no attribute '__exit__'
07:40:05 T:1781797504 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
Regards
(2015-09-28, 21:13)topki_111 Wrote: [ -> ]
Regards
I was right, the issue was caused by the different OS ID. service.bscfusion was set to "PC" while plugin.video.bscfusion was set to "Samsung" OS ID. That must have yielded the difference.
BTW, on my Android box I get the "Module Import failed" message after the Fusion program runs, just like Jappy and there is no *.xml.gz file created, but I will troubleshoot that tonight.
(2015-09-29, 08:05)harrygg Wrote: [ -> ]BTW, on my Android box I get the "Module Import failed" message after the Fusion program runs, just like Jappy and there is no *.xml.gz file created, but I will troubleshoot that tonight.
The same happens to me.
I am in Canada using 50 Mbps FTTN Internet, HD quality tearing and it is impossible to watch. Works stable only when switched OS ID to Pc (no HD quality)
Thank you again developers!
(2015-09-29, 14:01)moskivb Wrote: [ -> ]
I made some modifications, so can you remove folder "/storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/addons/service.bscfusion", install app and try again.
BTW what is your bandwidth to Sofia?
ping - 145 ms, danload - 35 Mbps, upload - 30 Mbps
When I use tivi.bg for watching TV I have no problems with HD channels . For me they are the best , but the owner is very cowardly and recently threw me out of there because he had no license for TV distribution outside Bulgaria , and my IP was from North America
I will install everything from scratch and share the effect of this .
Š¢hanks for your time
Hi Topki_111,
This is the error I get when trying to instal FusionTV from BG Addons repo, and indeed the zip file is not available at the given url. Is this a known issue?
20:12:52 44600.367188 T:1517286432 ERROR: CCurlFile::Open failed with code 404 for https://github.com/kodi1/kodi1.github.io...-0.0.1.zip
20:12:52 44600.367188 T:1517286432 ERROR: CAddonInstallJob[service.bscfusion]: failed to download special://home/addons/packages/service.bscfusion-0.0.1.zip
I can find it manually though, and download the zip from:
https://github.com/kodi1/service.bscfusion .
Then everything works just fine! EPG and channel icons work too.
Thanks & keep up the good work.
Harry
Hi Topki,
One more thing, btw I am the developer of the Gong.Play. I wanted to contact you in a private message but I am still considered a newbie and I don't have permissions to send private messages. So, can you change the link to the Gong Play addon in BG Repo?
It should be:
https://github.com/harrygg/plugin.video....g.play.zip
(version number removed), so I can only replace the zip when updating.
Thanks,
Harry
(2015-09-29, 19:36)harrygg Wrote: [ -> ]Hi Topki,
It should be:
Thanks,
Harry
So is latest version from git work on android?
I'll fix it in one or two hours.
(2015-09-29, 19:41)topki_111 Wrote: [ -> ]
It should be:
Thanks,
Harry
Yes it is working on android.
Fiew remarks:
- xbmc.python version 2.20.0 I cant achieve with Kodi 14.x. So I had to change it in required dependances to install latest version from github
- did not get how to get Channels Logos working (I think it is not the plugin problem)
Thank you for the good job.
Regards
(2015-09-29, 22:34)Jappy Wrote: [ -> ]- did not get how to get Channels Logos working (I think it is not the plugin problem)
Regards
I'm not sure, that iptv simple client, which is delivered whit kodi 14.x, sport loading logos from xmltv file.
Actually I didn't have the time to test it on Android yet, but on OSMC on Rasperberry PI 2 the Git version works! Channel logos work as well.
Perfect!
(2015-09-29, 23:12)topki_111 Wrote: [ -> ]I'm not sure, that iptv simple client, which is delivered whit kodi 14.x, sport loading logos from xmltv file.
Does not support them ,
http://kodi.wiki/view/Addon.xml
Do not waste your time with KODI 14 (no EPG and channel logos ) if you want 100% working Fusion TV, install KODI 15 and larger, they maintain xbmc.python version 2.20.0
