Full Version: guisettings location in Gotham?
Hi guys,
I'm building my own custom Android Gotham build. I've added a custom guisettings.xml to the userdata and system folder (like Frodo) but when it's installed I have the default settings and not my own. Is there a different way to do this in Gotham?
Did you add it to?
Android/data/org.xbmc.xbmc/files/.xbmc/userdata/
Adding it to the system folder will not make the changes, only the userdata folder.
Yes, I can get it working if I install manually. But what I'd like to do is copy it directly into the apk (re-build and sign) and have it already there when XBMC in installed.
