Hi, I can't get any farther than the homepage as everything I click on brings this message up. It was fine a couple of months ago and I haven't changed my PC set up. Is there an easy fix that I can access please? Please note I am not an expert so instructions will need to be very simple
Oh, c'mon... okay, so you're not an expert, but work with us here... what platform/OS - Linux, Windows, iOS, RSX, VM/CMS? Where is your media stored - locally, on USB, on a NAS, in the cloud, in the cupboard, on wax cylinders in the attic?
At least try to explain the situation even if you don't understand the problem. It sounds like your library is pointing to files that aren't available, but there are many reasons for that. A
debug_log (wiki) would be very helpful as that would answer many things.
Thanks for the reply, Its Windows and the media files are on the laptop.
The debug log is as follows, there is a lot of it
** log removed **
As you can imagine, nobody appreciates extremely long messages, especially pointless logs.
http://wiki.xbmc.org/index.php?title=Troubleshooting
http://wiki.xbmc.org/index.php?title=Log_file/Easy
I suspect that your sources are no longer configured properly (windows plays musical chairs with drive letters depending on when the source is recognized) and in doing so (a USB key addition can do it) the source is now gone. In all likelyhood you will have to re-establish (re-scan) your source and clean-up the library.
