Full Version: Moviesets
Not sure if this is an Aeon Nox or an XBMC13 thing but here goes:
With XBMC12 and the previous Aeon Nox moviesets would show fanart of the first movie in the set when browing through Movies. Like so: http://i.imgur.com/h7eaww8.png. Set is called "3D" and Alice in Wonderland happens to be the first one in the set.
However now with XBMC13 and the 4.1.9 version of Aeon Nox I get this: http://i.imgur.com/nR5bUEQ.png
I briefly tried Aeon Nox 5 and I believe it had the same issue.
How do I fix that? I have the moviesets script or whatever it is installed but I'm not sure how to use that. I'm not going to download and assign separate movieset art for each set manually as it is too much work and I'm fine with the first/latest/random movie in the set showing instead.
I don't let XBMC organize the sets by the way, I do that myself with Tiny Media Manager. If I let XBMC do it I end up with tons of "sets" with 1 movie in it for some reason.
http://forum.xbmc.org/showthread.php?tid=153502 or manual entry. Xbmc won't auto assign one other than the first. Sometimes, if you edit a set outside of Xbmc, you get missing values and incompatibilities unless you wipe the library. Xbmc doesn't take well to updating nfo files either unless you manually update since everything is already cached.
If you put a fanart.jpg and poster.jpg in the folder of the particular movieset, then those will be used.
You can force them by using the utility.
[RELEASE] Texture Cache maintenance utility
http://forum.xbmc.org/showthread.php?tid=158373
You can then run this command to update all your movieset artwork
texturecache.py C sets
There's some good trouble shooting tips in this thread:
http://forum.xbmc.org/showthread.php?tid...pid1521843
(2014-05-19, 03:31)McButton Wrote: [ -> ]http://forum.xbmc.org/showthread.php?tid=153502 or manual entry. Xbmc won't auto assign one other than the first. Sometimes, if you edit a set outside of Xbmc, you get missing values and incompatibilities unless you wipe the library. Xbmc doesn't take well to updating nfo files either unless you manually update since everything is already cached.
Well it's not even assigning the first movie in the set. It did before on v12.
