2014-05-18, 23:55
2014-05-18, 23:58
We do not support it on this website / forum. Only official build downloaded from our website
2014-05-18, 23:58
Some goobers made it. They preinstalled add-ons for people who are too lazy to manually install add-ons. Which also means you'll probably have some that you don't want that are preinstalled. I wouldn't use it.
2014-05-21, 21:58
Where is the best place to install it from then?
2014-05-21, 22:01
2014-05-21, 23:18
(2014-05-21, 22:01)jammyb Wrote: [ -> ]Erm. www.xbmc.org/download
but that only has Gotham
2014-05-21, 23:28
Read second reply
2014-05-21, 23:47
(2014-05-21, 23:18)Carolina48 Wrote: [ -> ](2014-05-21, 22:01)jammyb Wrote: [ -> ]Erm. www.xbmc.org/download
http://mirrors.xbmc.org/releases/android/
2014-08-14, 15:12
They say this version has been modified to work better on their Android box than on other boxes. They say their box doe not have the audio sync issues a lot of Android boxes have. I have a Minix X5 since a coupel of days and encounter these problems also. On my laptop I don not have these problems.
Does anybody know how I can solve these sync issues permanently?
2014-08-14, 18:12
your laptop will have better hardware then your android box
2014-08-14, 19:28
Of course, that's right.
I just resolved it, with a bypass. I set the lag to 0.333 seconds for all video's. I didn't know that option before,
2014-08-14, 19:50
2014-08-14, 23:15
(2014-08-14, 19:50)Ned Scott Wrote: [ -> ]Minix has a version of XBMC, and those minix-specific tweaks should also be in SPMC (wiki). If you still have issues then I would give SPMC (wiki) a try.
Thanks. I will check first which XBMC is running on my Minix. A friend of mine has installed and configured it for me.
