Full Version: Aeon Nox 5 Mod : Showcase and more
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27
So, as I'm using Aeon Nox 5 on my secondary HTPC (ION platform with Atom N330 + GeForce9300 with OpenELEC), I'm starting to mod it :
watch gallery
Some music features :
http://forum.kodi.tv/showthread.php?tid=...pid2282073
This mod will be light as I don't use Aeon Nox 5 on my main HTPC, I don't need all the feature I have put on my Aeon Nox 4.1 mod.
Download it :
Aeon Nox 5.1.5 ZIP file (Gotham) DEPRECATED
Aeon Nox 5.6.0 ZIP file (Helix) DEPRECATED
Aeon Nox 5.7.3 ZIP file (Isengard) DEPRECATED
Aeon Nox 5.8.6 ZIP file (Jarvis)
Aeon Nox 6.0.1 ZIP file (Krypton)
You need also to download and install script.skin.info.service.
Install it : copy files from 1080i folder and overwrite existing file in 1080i folder in aeon nox 5 skin directory. Do the same with media folder and language.
If you use CD Music wall as background, you need to copy service.library.data.provider folder in your userdata/addon_data.
For displaying widgets, that are now hidden, you need to install script.globalsearch from repo :
http://addons.kodi.tv/show/script.globalsearch/
Rolling disc and opening case are linked to Info panel. So you can manually display it by pressing UP key or use Aeon Nox 5 general settings for delay it, that what I'm using :
Credits : Phil65 and BigNoid for Aeon Nox 4 and 5
Frodo19 : For DVD/CD/BR cases
Looks great! Will download and test tomorrow when I can get to my HTPC
Just out of interest, when Aeon Nox auto-updates will we need to reapply these?
Nice. The delay option is already available under advanced settings. I will add this to the sticky.
(2014-05-20, 17:14)martinconroy Wrote: [ -> ]Just out of interest, when Aeon Nox auto-updates will we need to reapply these?
Yes, you will have re apply this mod after each skin update.
Nice, thank you! I really like AN5 and this one looks good. Looking forward to display discart option.
Does this work together with the "Minimalistic" AN5 mod? http://forum.xbmc.org/showthread.php?tid=192623
Discart FTW!
(2014-05-21, 06:40)tjsuominen Wrote: [ -> ]Does this work together with the "Minimalistic" AN5 mod? http://forum.xbmc.org/showthread.php?tid=192623
As long as you don't have to replace the same XML, the 2 mods can be installed together.
(2014-05-20, 18:28)BigNoid Wrote: [ -> ]Nice. The delay option is already available under advanced settings. I will add this to the sticky.
Thanks, found it and use it to open case :
Dropbox link updated in first post.
Thanks, this works well, though sometimes the disk doesn't appear though I guess that's the loading speed of the image over the network.
As a thought, it would be good to hide the infopanel for sets as this is usually fairly blank/meaningless?
Thanks again!
(2014-05-20, 17:10)mikebzh44 Wrote: [ -> ]extra script is needed for movieset (script.extendedinfo from Phil65) and I have to look how to add it into Aeon Nox 5.
That would be great
Please do Smile
Link updated in first post to add up to 6 discarts for movieset.
You need to install script.extendedinfo from Phil65 and moddded for Gotham by Azrael Omega : https://github.com/azraelomega/script.extendedinfo
Link updated to fix New / Watched / Partially watched overlay.
Question. Is there a way to JUST show the discart without opening a case? If I land on a single movie, can it display discart and when I land on a set can it be set up to just have all of the discs roll in? Thanks.
