Is it possible to disable the thin vertical progress bar that travels across the EPG in guide view?
Or perhaps add an option in advancedsettings.xml.
You can probably modify your skin to get rid of it. I doubt there will be an option for this since why would you want to remove it?
(2014-05-21, 09:22)negge Wrote: [ -> ]You can probably modify your skin to get rid of it. I doubt there will be an option for this since why would you want to remove it?
Thanks for the response. So it seems it is possible. I will research that more.
As to why to remove it? I've never seen a commercial EPG with that on it. I'm trying to make the DVR and Live TV seem as similar to what my family is use to with Comcast as possible. I personally find it distracting and unnecessary BUT that is only my opinion. Thanks again for the response
