Full Version: XBMCBUNTU NEED HELP!!! ALC272X
Pages: 1 2
i have installed latest xbmcbuntu 13
and when i booted into live environment i had sound
and then after install to hard drive it stopped working?
it is a alc272x chipset with alsa mixer if i put the mic all the way up i hear hissing coming from built-in speakers
I'm pretty much lost right now please help!! Sad
debug log (wiki)
I just sent you my xbmc log
hopefully you can help
Post your Debug Log in the forum ... Not everbody can read negge's PMs
1. 13:47:14 T:3031938880  NOTICE: special://profile/ is mapped to: special://masterprofile/
2. 13:47:14 T:3031938880  NOTICE: -----------------------------------------------------------------------
3. 13:47:14 T:3031938880  NOTICE: Starting XBMC (13.1-BETA1 Git:692cfba). Platform: x86 Linux 32-bit
4. 13:47:14 T:3031938880  NOTICE: Using Release XBMC x32 build, compiled May 13 2014 by GCC 4.8.2 for x86 Linux 32-bit 3.13.9
5. 13:47:14 T:3031938880  NOTICE: Running on Linux 32-bit (Ubuntu 14.04 LTS, 3.13.0-24-generic i686)
6. 13:47:14 T:3031938880  NOTICE: Host CPU: AMD Athlon™ Processor TF-20, 1 core available
7. 13:47:14 T:3031938880  NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
8. 13:47:14 T:3031938880  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
9. 13:47:14 T:3031938880  NOTICE: special://masterprofile/ is mapped to: /home/xbmc/.xbmc/userdata
10. 13:47:14 T:3031938880  NOTICE: special://home/ is mapped to: /home/xbmc/.xbmc
11. 13:47:14 T:3031938880  NOTICE: special://temp/ is mapped to: /home/xbmc/.xbmc/temp
12. 13:47:14 T:3031938880  NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
13. 13:47:14 T:3031938880  NOTICE: Local hostname: XBMC-PC
14. 13:47:14 T:3031938880  NOTICE: Log File is located: /home/xbmc/.xbmc/temp/xbmc.log
15. 13:47:14 T:3031938880  NOTICE: -----------------------------------------------------------------------
16. 13:47:15 T:3031938880  NOTICE: load settings...
17. 13:47:17 T:3031938880   ERROR: PulseAudio: Failed to connect context
18. 13:47:17 T:3031938880  NOTICE: PulseAudio might not be running. Context was not created.
19. 13:47:17 T:3031938880  NOTICE: Found 1 Lists of Devices
20. 13:47:17 T:3031938880  NOTICE: Enumerated ALSA devices:
21. 13:47:17 T:3031938880  NOTICE:     Device 1
22. 13:47:17 T:3031938880  NOTICE:         m_deviceName      : @:CARD=SB,DEV=0
23. 13:47:17 T:3031938880  NOTICE:         m_displayName     : HDA ATI SB
24. 13:47:17 T:3031938880  NOTICE:         m_displayNameExtra: ALC272X Analog
25. 13:47:17 T:3031938880  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
26. 13:47:17 T:3031938880  NOTICE:         m_channels        : FL,FR
27. 13:47:17 T:3031938880  NOTICE:         m_sampleRates     : 48000
28. 13:47:17 T:3031938880  NOTICE:         m_dataFormats     : AE_FMT_S32NE
29. 13:47:17 T:3031938880  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
30. 13:47:17 T:3031938880  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
31. 13:47:17 T:3031938880  NOTICE: Contents of special://profile/advancedsettings.xml are...
32.                                             <advancedsettings>
33.                                               <useddsfanart>true</useddsfanart>
34.                                               <cputempcommand>cputemp</cputempcommand>
35.                                               <gputempcommand>gputemp</gputempcommand>
36.                                               <samba>
37.                                                 <clienttimeout>30</clienttimeout>
38.                                               </samba>
39.                                               <network>
40.                                                 <disableipv6>true</disableipv6>
41.                                               </network>
42.                                             </advancedsettings>
43. 13:47:17 T:3031938880  NOTICE: Default DVD Player: dvdplayer
44. 13:47:17 T:3031938880  NOTICE: Default Video Player: dvdplayer
45. 13:47:17 T:3031938880  NOTICE: Default Audio Player: paplayer
46. 13:47:17 T:3031938880  NOTICE: Disabled debug logging due to GUI setting. Level 0.
47. 13:47:17 T:3031938880  NOTICE: Log level changed to 0
48. 13:47:17 T:3031938880  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
49. 13:47:17 T:3031938880  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
50. 13:47:17 T:3031938880  NOTICE: Loaded playercorefactory configuration
51. 13:47:17 T:3031938880  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
52. 13:47:17 T:3031938880  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
53. 13:47:17 T:2962123584  NOTICE: Thread ActiveAE start, auto delete: false
54. 13:47:17 T:2951740224  NOTICE: Thread AESink start, auto delete: false
55. 13:47:17 T:3031938880  NOTICE: Running database version Addons16
56. 13:47:18 T:3031938880  NOTICE: ADDONS: Using repository repository.qf.addons
57. 13:47:18 T:3031938880  NOTICE: ADDONS: Using repository repository.xbmc.org
58. 13:47:18 T:3031938880  NOTICE: ADDONS: Using repository repository.divingmule.addons
59. 13:47:18 T:3031938880  NOTICE: ADDONS: Using repository repository.mash2k3
60. 13:47:18 T:2941254464  NOTICE: Thread PeripBusCEC start, auto delete: false
61. 13:47:18 T:2932861760  NOTICE: Thread PeripBusUSBUdev start, auto delete: false
62. 13:47:18 T:3031938880  NOTICE: Setup SDL
63. 13:47:19 T:3031938880  NOTICE: Checking resolution 16
64. 13:47:19 T:3031938880  NOTICE: Using visual 0x24c
65. 13:47:19 T:3031938880  NOTICE: GL_VENDOR = X.Org
66. 13:47:19 T:3031938880  NOTICE: GL_RENDERER = Gallium 0.4 on AMD RS780
67. 13:47:19 T:3031938880  NOTICE: GL_VERSION = 3.0 Mesa 10.1.0
68. 13:47:19 T:3031938880  NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.30
69. 13:47:19 T:3031938880  NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_compression_s3tc GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_fog_distance GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_NV_primitive_restart GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_occlusion_query2 GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_ATI_texture_compression_3dc GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_rgtc GL_EXT_texture_mirror_clamp GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_ATI_texture_mirror_once GL_EXT_draw_buffers2 GL_EXT_draw_instanced GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_compression_latc GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_EXT_timer_query GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_instanced_arrays GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_AMD_conservative_depth GL_AMD_draw_buffers_blend GL_AMD_shader_stencil_export GL_ARB_ES2_compatibility GL_ARB_blend_func_extended GL_ARB_debug_output GL_ARB_draw_buffers_blend GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_stencil_export GL_ARB_shader_texture_lod GL_ARB_texture_multisample GL_ARB_texture_rgb10_a2ui GL_ARB_uniform_buffer_object GL_ARB_vertex_type_2_10_10_10_rev GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_NV_texture_barrier GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_shader_bit_encoding GL_ARB_timer_query GL_ARB_transform_feedback2 GL_ARB_transform_feedback3 GL_NV_vdpau_interop GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_base_instance GL_ARB_conservative_depth GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_shading_language_420pack GL_ARB_shading_language_packing GL_ARB_texture_storage GL_ARB_transform_feedback_instanced GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_transform_feedback GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_invalidate_subdata GL_ARB_texture_storage_multisample GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_texture_mirror_clamp_to_edge GL_ARB_vertex_type_10f_11f_11f_rev
70. 13:47:19 T:3031938880   ERROR: GLX: Same window as before, refreshing context
71. 13:47:19 T:3031938880  NOTICE: No Joystick name specified, loading default map
72. 13:47:19 T:3031938880  NOTICE: Previous line repeats 35 times.
73. 13:47:19 T:3031938880  NOTICE: Running database version Addons16
74. 13:47:19 T:3031938880  NOTICE: Running database version ViewModes6
75. 13:47:19 T:3031938880  NOTICE: Running database version Textures13
76. 13:47:19 T:3031938880  NOTICE: Running database version MyMusic46
77. 13:47:20 T:3031938880  NOTICE: Running database version MyVideos78
78. 13:47:20 T:3031938880  NOTICE: Running database version TV22
79. 13:47:20 T:3031938880  NOTICE: Running database version Epg7
80. 13:47:20 T:3031938880  NOTICE: start dvd mediatype detection
81. 13:47:20 T:3031938880  NOTICE: initializing playlistplayer
82. 13:47:20 T:3031938880  NOTICE: DONE initializing playlistplayer
83. 13:47:20 T:2884598592  NOTICE: Thread DetectDVDMedia start, auto delete: false
84. 13:47:21 T:3031938880 WARNING: JSONRPC: Could not parse type "GUI.Property.Value"
85. 13:47:21 T:3031938880 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
86. 13:47:21 T:2873015104  NOTICE: Thread LanguageInvoker start, auto delete: false
87. 13:47:21 T:3031938880  NOTICE: Previous line repeats 1 times.
88. 13:47:21 T:3031938880  NOTICE: initialize done
89. 13:47:21 T:3031938880  NOTICE: Running the application...
90. 13:47:21 T:2864622400  NOTICE: Thread LanguageInvoker start, auto delete: false
91. 13:47:21 T:2881407808  NOTICE: -->Python Interpreter Initialized<--
92. 13:47:21 T:2864622400  NOTICE: -->Python Interpreter Initialized<--
93. 13:47:21 T:2873015104  NOTICE: -->Python Interpreter Initialized<--
94. 13:47:22 T:2852649792  NOTICE: Thread JobWorker start, auto delete: true
95. 13:47:22 T:3031938880  NOTICE: starting zeroconf publishing
96. 13:47:22 T:3031938880  NOTICE: ES: Starting event server
97. 13:47:22 T:2819078976  NOTICE: Thread TCPServer start, auto delete: false
98. 13:47:22 T:2827471680  NOTICE: Thread EventServer start, auto delete: false
99. 13:47:22 T:2827471680  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
100. 13:47:22 T:2827471680  NOTICE: UDP: Listening on port 9777
101. 13:47:22 T:2835864384  NOTICE: Thread JobWorker start, auto delete: true
102. 13:47:22 T:2776075072  NOTICE: Thread RSSReader start, auto delete: false
103. 13:47:22 T:2864622400  NOTICE:  StorageServer Module loaded RUN
104. 13:47:22 T:2864622400  NOTICE: StorageClient-2.5.4 Starting server
105. 13:47:22 T:2864622400  NOTICE: StorageServer-2.5.4 Storage Server starting /home/xbmc/.xbmc/temp/commoncache.db
106. 13:47:22 T:2784467776  NOTICE: Thread FileCache start, auto delete: false
107. 13:47:23 T:2784467776  NOTICE: Thread AlarmClock start, auto delete: false
108. 13:47:23 T:2771385152  NOTICE: Thread FileCache start, auto delete: false
109. 13:47:24 T:2771385152  NOTICE: Previous line repeats 2 times.
110. 13:47:24 T:2771385152  NOTICE: Thread BackgroundLoader start, auto delete: false
111. 13:47:24 T:2771385152  NOTICE: Thread FileCache start, auto delete: false
112. 13:47:27 T:2771385152  NOTICE: Thread LanguageInvoker start, auto delete: false
113. 13:47:27 T:2771385152  NOTICE: -->Python Interpreter Initialized<--
114. 13:47:27 T:2873015104  NOTICE: Thread FileCache start, auto delete: false
115. 13:47:29 T:2873015104  NOTICE: Previous line repeats 2 times.
116. 13:47:29 T:2873015104  NOTICE: Thread BackgroundLoader start, auto delete: false
117. 13:47:30 T:2873015104  NOTICE: Thread FileCache start, auto delete: false
118. 13:47:31 T:2873015104  NOTICE: Thread BackgroundLoader start, auto delete: false
119. 13:47:53 T:2873015104  NOTICE: Thread LanguageInvoker start, auto delete: false
120. 13:47:53 T:2873015104  NOTICE: -->Python Interpreter Initialized<--
121. 13:48:25 T:2771385152  NOTICE: XBMC Log Uploader: started
122. 13:48:25 T:2771385152  NOTICE: XBMC Log Uploader: settings: len(email)=23
123. 13:48:25 T:2771385152  NOTICE: XBMC Log Uploader: settings: skip_oldlog=True
124. 13:48:33 T:2771385152  NOTICE: XBMC Log Uploader: reading log...
sorry for taking long x_x
aplay -L | pastebinit
amixer | pastebinit
http://paste.ubuntu.com/7524104/
amixer | pastebinit
http://paste.ubuntu.com/7524108/
speaker-test -c 2 -r 48000 -D plughw:0,0
yea the test worked both speakers test tones worked now how to make them work for playback..? =/
*BUMP*
Go there: and make the settings as shown in the screenshot:
IT WORKED thank you very much Smile
is there a way to boost volume? its kinda low even at max volume.
also is there a way to put volume amplification to stay for all movies?
check with alsamixer (from the shell) if your hw volume is not at low volume.
Also press "+" some times, it could be that internal xbmc volume is low.
For the second part: Save for all files. (but check the above first).
Pages: 1 2
