2020-08-08, 00:52
In Kodi set the display resolution to 3840x2160 and GUI resolution limit to Unlimited. Should give better results as most skins are coded for 1080p so textures will be scaled evenly and fonts will look nice and sharp.
(2014-05-21, 10:24)ronie Wrote: [ -> ]someone just needs to buy all of us a 4K TV right? ;-)
(2020-08-08, 00:52)Hitcher Wrote: [ -> ]In Kodi set the display resolution to 3840x2160 and GUI resolution limit to Unlimited. Should give better results as most skins are coded for 1080p so textures will be scaled evenly and fonts will look nice and sharp.
(2021-11-25, 12:51)YvesB Wrote: [ -> ](2020-08-08, 00:52)Hitcher Wrote: [ -> ]In Kodi set the display resolution to 3840x2160 and GUI resolution limit to Unlimited. Should give better results as most skins are coded for 1080p so textures will be scaled evenly and fonts will look nice and sharp.
Display resolution is greyed, 192x 1080p, and can not be changed.
(Kodi 19.3)
(2021-11-25, 19:57)Hitcher Wrote: [ -> ]Then your device doesn't support 4k.Hitcher,
(2021-11-26, 10:47)Hitcher Wrote: [ -> ]Probably limited by the OS. Please post a full debug log.Thank you, here is the log link :
The instructions are here... debug log (wiki)
1.Enable debugging in Settings>System Settings>Logging,
2.Restart Kodi
3.Replicate the problem.
4.Upload the log to Kodi Paste Site manually or use the Kodi Logfile Uploader. (wiki) With either method post the link to the log back here.
If you are using the Advanced Method ensure you have correctly created and applied the advancedsettings.xml file (wiki)
In both instances, you should see the word DEBUG throughout the log.
Do NOT post your logs directly into the forum. Use the Kodi Paste Site. Post the link to your pasted log in the forum
(2021-11-26, 09:56)YvesB Wrote: [ -> ]What else could be wrong pls ?
2021-11-26 10:20:58.216 T:26742 DEBUG <general>: CAndroidUtils: current mode: 1: [email protected]
2021-11-26 10:20:58.217 T:26742 DEBUG <general>: CAndroidUtils: available mode: 1: [email protected]
2021-11-26 10:20:58.217 T:26742 DEBUG <general>: CAndroidUtils: maximum/current resolution: 1920x1080
2021-11-26 10:20:58.217 T:26742 DEBUG <general>: CAndroidUtils: selected resolution: 0x0
Quote:Some Android TV devices run their UI layer at a resolution that’s lower than the full resolution of the display, upscaling it for presentation to the user. For example, the UI layer may be run at 1080p on an Android TV that has a 4K display.
