Full Version: Custom Window
I have a custom RSS window with a z order of 0. When a control below is visible, I want to fade the custom window. However can't think of a way to achieve it.
Usual visible code isn't having any effect, due to the custom windows z order placing the window on top of the control that's controlling the visibility.
Any ideas on a simple solution?
Cheers
Could it be not working because the control (that's controlling the visibility) is part of an include, and not an item on a specific window (like Home)?
You can't use controls from other windows in the conditions for a custom window only whether another window is visible or not.
Have you tried using Window Properties?
Thought so. The window properties won't apply for what I'm trying.
Cheers buddy
