Has anyone noticed XBMC being really dark? I am on this version xbmc-20140518-a6a2713-Gotham-armeabi-v7a.apk
I may be wrong but I think it may have started after I installed fusion. The screen is really dark, not just for moving but for all XBMC screens. Other apps on the firetv look just fine.
Stop using things from fusion.
(2014-05-21, 20:13)Martijn Wrote: [ -> ]Stop using things from fusion.
Oh, what should I use then? And why do you recommend against fusion?
(2014-05-21, 20:23)badnaam Wrote: [ -> ] (2014-05-21, 20:13)Martijn Wrote: [ -> ]Stop using things from fusion.
because its 3rd party bundled stuff, usually packed full of junk. Not supported here
(2014-05-22, 00:05)riaz1982 Wrote: [ -> ] (2014-05-21, 20:23)badnaam Wrote: [ -> ] (2014-05-21, 20:13)Martijn Wrote: [ -> ]Stop using things from fusion.
OK. Is there a supported/better way of getting some of the add ons like icefilms?
