2014-05-21, 22:40
Hey guys,
i have a problem:
On my nexus 10, as well as on my nexus 5 avc-remux (vc1) files are stuttering and they are running with maybe 10 fps.
In my opinion it seems that the hardware of the devices is not powerful enough to play these type of files.
Is this possible? All hardware acceleration is enabled and i'm using xbmc 13.
Here is an example of the file i want to play (extracted with mediainfo):
Thanks in advance!
Tylsen
i have a problem:
Quote:Format : Matroska
Format version : Version 2
File size : 17.9 GiB
Duration : 2h 16mn
Overall bit rate mode : Variable
Overall bit rate : 18.8 Mbps
Encoded date : UTC 2011-01-25 10:20:56
Writing application : mkvmerge v3.3.0 ('Language') gebaut am Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : VC-1
Format profile : Advanced@L3
Codec ID : V_MS/VFW/FOURCC / WVC1
Codec ID/Hint : Microsoft
Duration : 2h 16mn
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Default : No
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 16mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 624 MiB (3%)
Language : German
Default : Yes
Forced : No
Audio #2
Format : TrueHD
Codec ID : A_TRUEHD
Duration : 2h 16mn
Bit rate mode : Variable
Maximum bit rate : 3 345 Kbps
Compression mode : Lossless
Language : English
Default : No
Forced : No
Text
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : German
Default : No
Forced : No
Thanks in advance!
Tylsen
