I'm referring to the circular animation when loading streams from the internet...
I'd like to change this if possible
It is not possible without "hacking" the code of the skin.
Peppe
Well yes, that seems pretty obvious.
Do you care to elaborate on the "how" of my question?
there is nothing to elaborate answer is "It is not possible"
only way to change the animation is edit the code.
thing that i'm not able to do.
you should open the skin folder search the right part and try yourself. and this in obvious too.
Peppe
