Full Version: UnicodeEncodeError in translation file
http://forum.xbmc.org/showthread.php?tid...pid1718543
The Portuguese translated strings.po is causing an error in my addon. Is this common? I would have thought the translation service would prevent this from happening?
What should I do? Just delete the offending string?
Use something like this
PHP Code:
def localise(id):
string __addon__.getLocalizedString(id).encode'utf-8''ignore' )
    return
string
where you throw all localisations through
Not sure if it the .po should prevent this.
