Full Version: Cannot Find the Add-on
I feel really stupid here but I cannot find the add-on for NextPVR
I am running windows 7 and Gotham 13.1 beta
If I go to
Add-ons XBMC.org PVR add-ons it is empty
Add-ons All Add-ons PVR Clients I can see Argus, DVBlink, PVR IPTV, WMC client
I have found a version from 26-11-13 which was meant to work with Gotham but it won't manually install
Many thanks for your help
Just downgraded to 13.0 and found it no problem
With the add on installed now, you should be able yo upgrade to the betas and the add on will stay installed. Although if the add on API changes and no new add on is included, the add on may be reported as broken.
Would be nice if you told us where you found it!
Now another couple of hours down the drain searching.
So... Am I to assume to add on is broken?
Or will the Kricker enlighten us on where to find it?
(2014-11-06, 21:01)asdre Wrote: [ -> ]So... Am I to assume to add on is broken?
No, it's not broken, and I checked it's still there in default install on Windows. I assume it's there in other platforms too, but I don't use these other platforms, so can't check for you.
Do you see the other PVR addons, like Argus, Mediaportal, etc?
