2014-05-25, 14:22
With 3.9 i performed the following to setup my old recordings due to the HD channels carring "Now and Next" mheg data, to setup these recordings i used the channel for example "TV One + 1" the SD version but an hour delayed.
Once i had added a recording i would change the channel for the automatic recording to the HD variant.
Log is showing that it is still creating the recordings from the delayed SD channel instead of using the HD channel.
Even though i remove the scheduled recording from the upcomming recordings they get re added with the original channel and not the HD one that i want them to use.
sample autorec from .hts/tvheadend/autorec
Is this a bug and is is known about yet?
HTS Tvheadend 3.9.692~gf36be10
May 25 23:52:07 xbmc tvheadend[12808]: dvr: "Rheem Outdoors With Geoff" on "TV3 PLUS1": Updated Timer
May 25 23:52:08 xbmc tvheadend[12808]: dvr: "Trade Zone Gone Fishin'" on "TV3 PLUS1": Updated Timer
May 25 23:52:18 xbmc tvheadend[12808]: dvr: "Coastwatch" on "TV ONE plus 1": Updated Timer
May 25 23:52:18 xbmc tvheadend[12808]: dvr: "The ITM Fishing Show" on "TV ONE plus 1": Updated Timer
"id": "2",
"enabled": 1,
"config_name": "",
"creator": "192.168.1.2",
"comment": "Created from EPG query",
"channel": "af0e8af023174064b059fb3224f19100",
"contenttype": 160,
"title": "The ITM Fishing Show",
"approx_time": 0,
"weekdays": [
1,
2,
3,
4,
5,
6,
7
"pri": "normal",
"serieslink": "crid://crid://tvnz.co.nz/1020407"
