When ever I delete an episode in my shows folder it clears all episodes. The other episodes are not deleted I have to refresh the folder by hitting the back button to get to the main recordings list then reselect the show to move on the the next episode. Is there a way to refresh the folder without leaving the folder?
If you are using something that changes the title of the folder (ie; by appending the number of episodes) then this is what causes this to happen.
Yeah, please confirm whether the folder name actually changes after you delete a recording. If not it's a bug since it shouldn't be necessary to reenter the directory.
The title of the folder remains the same.
I'll attempt to reproduce this, in the meantime could you file a report on trac.xbmc.org and attach a debug log from when you delete something?
