(2014-11-05, 01:37)MrReis Wrote: [ -> ]Will there be an Android version of this client?
It is in active development. There are many things that are to be ported.
Dear all,
Everyone seems to be happy here with the App, so I want to be. I followed every step in Video-Settings.
Playlist URL
http://iptv.kerch.net//playlist/test.m3u
EPG URL
http://linux-sat.tv/epg/tvprogram_ua_ru.gz
And I have faced following issues:
1) I cant load LOGOS. I type d:\Logos-press OK-icon loading appears-but then nothing happens (logos list is still empty)
2) When I am in Play Mode and want to open a channel, I double click on the channel - at the bottom of a screen new icon appears, where circle on the right starts turning and then becomes red. So I cant open ANY of the channels I see there.
Please advise
(2014-11-13, 14:55)AndreiBbz Wrote: [ -> ]...
Please advise
This playlist URL is shown as example. You sholud get playlist URL from your internet provider or add playlist with links that work world wide.
As for logos, you sholud find and put logos images into some directory and set it in app's properties. There are many logos packs in internet.
(2014-11-13, 19:02)nikman Wrote: [ -> ]This playlist URL is shown as example. You sholud get playlist URL from your internet provider or add playlist with links that work world wide.
So, you want to say, that the video with PP settings you made - will work only in your country and I cant use these URLs?
The thing is that I need all those Russian channel you have in the video )))
Hi!
At last, Android beta version of Perfect Player published!
Meet the Android version
Waiting for your feedbacks...
Also, PC version will be updated soon. Greatly improved performance and memory optimizations especially with huge channels quantity, URL duplications resolving etc...
(2014-12-16, 12:17)nikman Wrote: [ -> ]Hi!
At last, android beta version of Perfect Player published!
Meet the android version
EDIT: It seems that local paths for the m3u playlist doesn't work.
I've put the playlist on a local web server and that works now.
Could please add support for local storage paths like /mnt/sdcard/playlist.m3u.
Otherwise a very useful app with great potential.
Doesn't work for me.
Empty channel list and no EPG.
For testing purposes, I use a local, short m3u channel list like this one:
#EXTM3U
#EXTINF:-1 tvg-id="ARD.de" tvg-logo="ard.png",ARD
http://xxxxxx-lh.akamaihd.net/i/daserste_1@97481/index_400_av-p.m3u8
#EXTINF:-1 tvg-id="ZDF.de" tvg-logo="zdf.png",ZDF
http://xxxxxx-lh.akamaihd.net/i/zdf_1@97483/index_400_av-p.m3u8
And xmltv EPG from here:
http://tiny.cc/epgde
Both work perfectly with "IPTV simple"
PS: what do I have to fill into (and is it necessary?): "IPTV data server"
(2014-12-21, 05:33)vel2000 Wrote: [ -> ]EDIT: It seems that local paths for the m3u playlist doesn't work.
You are right. Loading playlist and EPG from local paths will be added in the next release.
IPTV data server is also next release feature (not used by now).
Hi
i use your media player (windows version) and really like it
it's easy and fast
Some features that need to be added
- Keyboard shortcuts editor (i use remote control and hate default hotkeys)
- enable/disable Hardware Acceleration
- preferred auto EPG mapping source (when used more then one EPG Urls)
- configurable OSD / font size
thx
and
keep up the good working
New version for Android released
PerfectPlayer-0.7.0
(2015-01-05, 11:07)Hardly Wrote: [ -> ]- Keyboard shortcuts editor (i use remote control and hate default hotkeys)
You can try
EventGhost utility to setup mapping of your RC events to app's shortcuts keypresses.
I can send you EventGhost's config as a starting point if needed.
Hardly Wrote:- enable/disable Hardware Acceleration
Agree. By the way, the last Android version already has
Font size preference in setttings.
Hardly Wrote:- preferred auto EPG mapping source (when used more then one EPG Urls)
The first row in EPG URLs table has maximum priority for auto mapping, second has less and so on...
New version released
Perfect Player 1.1.2
Added Spanish and Ukrainian localizations, some new features and improvements.
great app..!! may i ask.. i run in in fullscreen in the second monitor but when i mark or click on other app on first monitor perfect player minimized on second monitor.. can i fix this?
(2015-01-16, 17:13)Ultralord Wrote: [ -> ]great app..!! may i ask.. i run in in fullscreen in the second monitor but when i mark or click on other app on first monitor perfect player minimized on second monitor.. can i fix this?
It's because it uses
exlusive fullscreen mode. Thus, video playback and OSD rendering should run smoother.
What you need is called
windowed mode. It's rather usual window without decorations. Think I should add this feature later.
