2014-05-27, 06:34
Hey guys, I upgraded my old crappy ATV2s for new FTVs and now I'm having a little bit of issues with recently updated TV shows. They don't show up as new, they load into the library correctly but they don't show up as "recent" I added the advanced settings XML with the proper format as I took it directly from my main HTPC which works fine, but none of my 4 FTVs are seeing TV shows as new. When I add a movie however it marks them as recently added. Is there something I missed?
i'm running Gotham on all of my systems. and the Dubug log looks like it's loading the xml file fine... any thoughts?
code]
20:19:22 T:1525495256 NOTICE: special://profile/ is mapped to: special://masterprofile/
20:19:22 T:1525495256 NOTICE: -----------------------------------------------------------------------
20:19:22 T:1525495256 NOTICE: Starting XBMC (13.0 Git:20140505-f42f5b5). Platform: ARM Android 32-bit
20:19:22 T:1525495256 NOTICE: Using Debug XBMC x32 build, compiled May 5 2014 by GCC 4.8.0 for ARM Android 32-bit API level 14
20:19:22 T:1525495256 NOTICE: Running on Android 32-bit API level 17 (Android, 3.4.0-perf-g6050c7d-00001-g74c30a8 armv7l)
20:19:22 T:1525495256 NOTICE: Host CPU: ARMv7 Processor rev 0 (v7l), 4 cores available
20:19:22 T:1525495256 NOTICE: Product: bueller, Device: bueller, Board: MSM8960 - Manufacturer: Amazon, Brand: qcom, Model: AFTB, Hardware: qcom
20:19:22 T:1525495256 NOTICE: ARM Features: Neon enabled
20:19:22 T:1525495256 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
20:19:22 T:1525495256 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.xbmc/cache/apk/assets
20:19:22 T:1525495256 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/userdata
20:19:22 T:1525495256 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc
20:19:22 T:1525495256 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/temp
20:19:22 T:1525495256 NOTICE: The executable running is: /system/bin/app_process
20:19:22 T:1525495256 NOTICE: Local hostname: localhost
20:19:22 T:1525495256 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.xbmc/files/.xbmc/temp/xbmc.log
20:19:22 T:1525495256 NOTICE: load settings...
20:19:22 T:1525495256 DEBUG: static int CAndroidFeatures::GetVersion(): android.os.Build.VERSION 17
20:19:22 T:1525495256 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/settings.xml
20:19:22 T:1525495256 DEBUG: CSettings: loaded settings definition from special://xbmc/system/settings/android.xml
20:19:22 T:1525495256 NOTICE: Found 1 Lists of Devices
20:19:22 T:1525495256 NOTICE: Enumerated AUDIOTRACK devices:
20:19:22 T:1525495256 NOTICE: Device 1
20:19:22 T:1525495256 NOTICE: m_deviceName : AudioTrack
20:19:22 T:1525495256 NOTICE: m_displayName : android
20:19:22 T:1525495256 NOTICE: m_displayNameExtra: audiotrack
20:19:22 T:1525495256 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
20:19:22 T:1525495256 NOTICE: m_channels : FL,FR
20:19:22 T:1525495256 NOTICE: m_sampleRates : 48000
20:19:22 T:1525495256 NOTICE: m_dataFormats : AE_FMT_S16LE,AE_FMT_AC3,AE_FMT_DTS
20:19:22 T:1525495256 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
20:19:22 T:1525495256 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
20:19:22 T:1525495256 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<videolibrary>
<dateadded>0</dateadded>
</videolibrary>
<network>
<cachemembuffersize>0</cachemembuffersize>
</network>
</advancedsettings>
20:19:22 T:1525495256 NOTICE: Default DVD Player: dvdplayer
20:19:22 T:1525495256 NOTICE: Default Video Player: dvdplayer
20:19:22 T:1525495256 NOTICE: Default Audio Player: paplayer
20:19:22 T:1525495256 NOTICE: Enabled debug logging due to GUI setting (2)
20:19:22 T:1525495256 NOTICE: Log level changed to 2
20:19:22 T:1525495256 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
20:19:22 T:1525495256 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
20:19:22 T:1525495256 DEBUG: CPlayerCoreConfig::<ctor>: created player DVDPlayer for core 1
20:19:22 T:1525495256 DEBUG: CPlayerCoreConfig::<ctor>: created player oldmplayercore for core 1
20:19:22 T:1525495256 DEBUG: CPlayerCoreConfig::<ctor>: created player PAPlayer for core 3
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: system rules
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtv
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: hdhomerun/myth/mms/udp
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: lastfm/shout
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtmp
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: rtsp
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: streams
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: aacp/sdp
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: mp2
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvd
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: dvdimage
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: sdp/asf
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: nsv
20:19:22 T:1525495256 DEBUG: CPlayerSelectionRule::Initialize: creating rule: radio
20:19:22 T:1525495256 NOTICE: Loaded playercorefactory configuration
20:19:22 T:1525495256 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
20:19:22 T:1525495256 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
20:19:22 T:1525495256 INFO: creating subdirectories
20:19:22 T:1525495256 INFO: userdata folder: special://masterprofile/
20:19:22 T:1525495256 INFO: recording folder:
20:19:22 T:1525495256 INFO: screenshots folder:
20:19:22 T:1525495256 INFO: load language info file: special://xbmc/language/English/langinfo.xml
20:19:22 T:1525495256 DEBUG: trying to set locale to en_US.UTF-8
20:19:22 T:1525495256 INFO: global locale set to C
20:19:22 T:1525495256 INFO: load English language file, from path: special://xbmc/language/
20:19:22 T:1525495256 DEBUG: POParser: loaded 3162 strings from file /data/data/org.xbmc.xbmc/cache/apk/assets/language/English/strings.po
20:19:22 T:1525495256 DEBUG: SECTION:LoadDLL(libavutil-52-arm.so)
20:19:22 T:1525495256 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libavutil-52-arm.so
20:19:22 T:1525495256 DEBUG: SECTION:LoadDLL(libavcodec-54-arm.so)
20:19:22 T:1525495256 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libavcodec-54-arm.so
20:19:22 T:1525495256 DEBUG: SECTION:LoadDLL(libavformat-54-arm.so)
20:19:22 T:1525495256 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libavformat-54-arm.so
20:19:22 T:1540310592 NOTICE: Thread ActiveAE start, auto delete: false
20:19:22 T:1553297264 NOTICE: Thread AESink start, auto delete: false
20:19:22 T:1553297264 INFO: CActiveAESink::OpenSink - initialize sink
20:19:22 T:1553297264 DEBUG: CActiveAESink::OpenSink - trying to open device AUDIOTRACK:AudioTrack
20:19:22 T:1553297264 DEBUG: CActiveAESink::OpenSink - AUDIOTRACK Initialized:
20:19:22 T:1553297264 DEBUG: Output Device : android
20:19:22 T:1553297264 DEBUG: Sample Rate : 48000
20:19:22 T:1553297264 DEBUG: Sample Format : AE_FMT_S16NE
20:19:22 T:1553297264 DEBUG: Channel Count : 2
20:19:22 T:1553297264 DEBUG: Channel Layout: FL,FR
20:19:22 T:1553297264 DEBUG: Frames : 1536
20:19:22 T:1553297264 DEBUG: Frame Samples : 3072
20:19:22 T:1553297264 DEBUG: Frame Size : 4
20:19:22 T:1540310592 DEBUG: SECTION:LoadDLL(libswresample-0-arm.so)
20:19:22 T:1540310592 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libswresample-0-arm.so
20:19:22 T:1525495256 NOTICE: Running database version Addons16
20:19:22 T:1525495256 DEBUG: SECTION:LoadDLL(libcpluff-arm.so)
20:19:22 T:1525495256 DEBUG: Loading: /data/app-lib/org.xbmc.xbmc-1/libcpluff-arm.so
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.json has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.fanart.tv has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in webinterface.default has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in repository.xbmc.org has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.vdr.vnsi has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.black has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.argustv has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in visualization.vortex has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.mediaportal.tvserver has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in weather.wunderground has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in script.module.simplejson has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in screensaver.xbmc.builtin.dim has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in script.favourites has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.themoviedb.org has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in service.xbmc.versioncheck has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.metadata has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvblink has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in skin.confluence has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in visualization.glspectrum has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in script.randomandlastitems has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in script.module.pil has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.gui has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in service.skin.widgets has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.amazon.de has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.vuplus has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.musicvideos.theaudiodb.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.core has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.demo has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in skin.touched has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.iptvsimple has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.wmc-android-arm has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in skin.blackglassnova has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.pvr has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.njoy has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.nextpvr has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in repository.pvr-android.xbmc.org has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in skin.hybrid has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.album.universal has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.htbackdrops.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.dvbviewer has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.mythtv.cmyth has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in script.xbmc.debug.log has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.tvdb.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.musicbrainz.org has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.allmusic.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.local has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.last.fm has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.themoviedb.org has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.debug has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.theaudiodb.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.artists.universal has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.python has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.imdb.com has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in pvr.hts has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.addon has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in visualization.waveform has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in xbmc.codec has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Plug-in metadata.common.hdtrailers.net has been installed.'
20:19:22 T:1525495256 DEBUG: ADDON: cpluff: 'Not all directories were successfully scanned.'
20:19:22 T:1525495256 NOTICE: ADDONS: Using repository repository.xbmc.org
20:19:22 T:1525495256 NOTICE: ADDONS: Using repository repository.pvr-android.xbmc.org
20:19:22 T:1525495256 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Motorola Nyxboard Hybrid"
20:19:22 T:1525495256 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "CEC Adapter"
20:19:22 T:1525495256 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "Pulse-Eight CEC Adapter"
20:19:22 T:1525495256 DEBUG: bool PERIPHERALS::CPeripherals::LoadMappings() - loaded node "iMON HID device"
20:19:22 T:1525495256 DEBUG: PERIPHERALS::CPeripheralBusUSB::CPeripheralBusUSB(PERIPHERALS::CPeripherals*) - using libusb peripheral scanning
20:19:22 T:1525495256 DEBUG: SECTION:LoadDLL(libcec.so)
20:19:22 T:1525495256 DEBUG: Loading: /system/lib/libcec.so
20:19:22 T:1525495256 WARNING: Unable to resolve: libcec.so CECInitialise, reason: Symbol not found:
20:19:22 T:1525495256 ERROR: Unable to resolve exports from dll libcec.so
20:19:22 T:1525495256 ERROR: virtual void PERIPHERALS::CPeripherals::Initialise() - failed to initialise bus cec
20:19:22 T:1555143736 NOTICE: Thread PeripBusUSB start, auto delete: false
20:19:22 T:1525495256 NOTICE: virtual bool CWinSystemEGL::InitWindowSystem(): Using EGL Implementation: android
