On my home screen I have a button for "movies" and a button for "television". When I click on "television" some of my shows are shown, but new ones are not shown. However, if I browse directly to "videos" and then to "files" I can see my shows listed under "television". I do not understand the difference between these two methods of accessing my television shows. I have tried removing the source and adding it again, but that didn't work. Any ideas?
Are they being added though ?
If they have not been picked up by the inbuilt scraper you will see them under files, but not from the TV menus, so you need to make sure they are being added by naming the folders correctly.
The ones showing from the TV menu probably are.
http://wiki.xbmc.org/index.php?title=Nam...s/TV_shows follow this guide and see if it helps
Yup, you were right. I was using descriptions from imdb, but once I used the descriptions from tvdb.com it found them. Easy solution. Thanks!
