Full Version: Clone setup/configuration
I have two XBMC PC's and use the Aeon Nox 5 on my main unit.
If I spend today configuring the background, custom icons etc is there an easy way to copy/clone this configuration to the other install? (Obviously I'll have to copy the images and icosn over etc)
thanks
Yes, there surely is.
On a Windows machine you go to c:\users\YOURUSERNAME\Appdata\Roaming there is a folder for XBMC. What i normally do is rename the folder to something like xbmcOLD, so that you have a backup for incase. Then copy the xbmc folder from the newly configured machine to the other. Done, easy as pie Wink
Just note, the AppData folder is hidden, so you need to either
  1. Type in the address in the bar manually
  2. Turn on hidden files and folders
  3. go to start, run and type %appdata% to open the appdata, then just navigate to roaming
Thanks - I'll give that a go, but with fifty seven thousand files it might take a while!
