2014-05-29, 17:30
Hello.
The trakt.tv addon is broken with XBMC 13.0 (Gotham) and an external player (MPC-HC in my case).
It seems that the python function "onPlayBackStarted(self)" of the trakt addon in https://github.com/trakt/script.trakt/bl...service.py is never called.
So I tried digging into the logs, trakt python code and XBMC code.
What I've found :
The first difference for the trakt addon in the XBMC logs when it works :
XBMC Logs - Internal player (working) :
The trakt function "onPlayBackStarted(self)" in service.py in the trakt addon code is never called with the external player.
XBMC Logs - External player (not working) :
It seems it corresponds to the XBMC function : "CApplication::OnPlayBackStarted()".
I found these "CApplication::OnPlayBack*" XBMC functions in https://github.com/xbmc/xbmc/blob/master...cation.cpp.
These "CApplication::OnPlayBack*" functions have a python call in their code.
The calls of "OnPlayBackStarted()", "OnPlayBackStopped()" and "OnPlayBackEnded()" are all only made once and in a switch on "m_ePlayState".
XBMC code - Application.cpp :
Here more informations and XBMC + trakt in debug logs :
http://forum.xbmc.org/showthread.php?tid...pid1719543
http://forum.xbmc.org/showthread.php?tid...pid1720497
The fault to the XBMC code in https://github.com/xbmc/xbmc/blob/master...cation.cpp ?
I don't know if it's a problem with the addon or with XBMC now...
Hope someone can finally help and solve this problem. I'm not a dev, sorry.
Contact me if you need more informations.
Cheers.
What I've found :
NOTICE: [trakt] [traktPlayer] onPlayBackStarted() - {u'item': {u'type': u'movie', u'id': 269, u'label': u'Welcome To The Jungle'}}
DEBUG: CApplication::OnPlayBackStarted : play state was 1, starting 1
DEBUG: CApplication::PlayFile : OpenFile succeed, play state 2
DEBUG: CApplication::OnPlayBackStarted : play state was 2, starting 0
DEBUG: CApplication::OnPlayBackStopped : play state was 2, starting 0
DEBUG: CApplication::PlayFile : OpenFile succeed, play state 1
DEBUG: CApplication::OnPlayBackEnded : play state was 1, starting 0
void CApplication::OnPlayBackEnded()
void CApplication::OnPlayBackStarted()
void CApplication::OnPlayBackStopped()
+ PlayBackRet CApplication::PlayFile(const CFileItem& item, bool bRestart)
// play state: none, starting; playing; stopped; ended.
// last 3 states are set by playback callback, they are all ignored during starting,
// but we recorded the state, here we can make up the callback for the state.
CLog::Log(LOGDEBUG,"%s : OpenFile succeed, play state %d", __FUNCTION__, m_ePlayState);
switch (m_ePlayState)
case PLAY_STATE_PLAYING:
OnPlayBackStarted();
break;
// FIXME: it seems no meaning to callback started here if there was an started callback
// before this stopped/ended callback we recorded. if we callback started here
// first, it will delay send OnPlay announce, but then we callback stopped/ended
// which will send OnStop announce at once, so currently, just call stopped/ended.
case PLAY_STATE_ENDED:
OnPlayBackEnded();
break;
case PLAY_STATE_STOPPED:
OnPlayBackStopped();
break;
case PLAY_STATE_STARTING:
// neither started nor stopped/ended callback be called, that means the item still
// not started, we need not make up any callback, just leave this and
// let the player callback do its work.
break;
default:
break;
Cheers.
